Kikat - Wasser Firmware for Beelink R89
Most certainly root by default please.
Just managed to get root to work although I have noticed that when rebooting, twice so far the reboot has not worked, just a no signal message on my TV, which required me to pull the power plug to get it to boot up again.
Still have to install the Kitkat external SD card patch 1.0 from the play store to enable write access. Can this be applied within the ROM as this is the first time that I have had to carry out such a procedure?
Fake ID vulnerbility still needs patching with xposed installer.
MX Player playing everything that I can throw at it with default HW settings.
SPMC 13.3.4 beta1 working well too and as before.
LED still on blue when in sleep mode.
Everything else working as with the 2.0.0 ROM.Last edited by bluesmanuk; 08 December 2014, 13:18.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by roolmapool View PostDid you try xvid/dix codecs files on stock/MX H/W? i have a slow motion effect on, like a 10 FPS... it's ok on xbmx/spmc.
If you have links to some specific files, I'll happily test to compare notes.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bluesmanuk View PostYes, I have a catalogue of about 60 files, covering all manner of codecs, including xvid/divx but saw no issues.
So not a big deal because i use SPMC ;-)
oh, wasser, another little issue ... i haven't location service. It's in gray... Can't turn on.
All feed back with 2.02 non rooted rom.
Thx.
2. Fake ID vulnerbility will be included in 2.0.2 final
3. about LED issue, which PCB version do you have?
Thanks again for your report.
Wasser
LED issue report
Hi Folks
i don't think it's difficult to test LED and and i don't think it breaks your device by this testing. It doesn't take time, just press power button and see if led is red or blue! it's all
Please test and report back and tell me which PCB version you have, if you want this issue fixed in 2.0.2!
Wasser
Originally posted by roolmapool View PostOK. Strange... in my case, all xvid files with AC3 sound are crap (like 15 FPS) in HW or HW+. No problem with xvid without AC3, or in S/W.
Thx.
wasser
Originally posted by wasser View Post1. Kitkat external SD card patch will be included in 2.0.2 final
Wasser
I have the original PCB 2R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Thx.
Stock player played the audio perfectly but frame rate was around 20fps.
The only player to play correctly was Archos video player.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by bluesmanuk View PostI just downloaded an X264 file with AC3 and when playing through SPMC or MX Player there was an echo to all the sound and also the frame rate did seem to be around 15fps.
Originally posted by roolmapool View PostYep, issue seems related to codecs audio DD/AC3...
This was a much longer file, so was very surprised at the result.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
There are currently 2841 users online. 0 members and 2841 guests.
