Wasser
Kikat - Wasser Firmware for Beelink R89
Sorry to ask, but I've searched the Tronsmart R28 Pro forum and i did not find the answer.
Before flashing Wasser 2.0.2 firmware, I think it's better to ask, if something goes wrong. Is it possible to revert to stock firmware (110K4)? And how to do this? Thank you
LE: Is the same procedure as installing the Wasser firmware but with the stock ROM from the producer's site?Last edited by aboicu; 10 December 2014, 15:46.
Flashed the ROM and done some testing.
External SD card write is fixed.
FakeID vulnerability still requires manual patching.
At the top of the notification tray there is usually an indicator with 3 lines that you click to clear the entries from the drop down list. This is no longer present.
Videos play as perfectly as they can at this time and the same as with the 2.0.2 beta.
Everything else, just as before and no issues for me.
Nice to know what one of the PCB changes was between 2 and 3 with regards to the LED not having any form of control on the original.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Thanks for rom Wasser!
Something:
- is it possible to fix search in Netflix? Using Logitech keyboard and when i press one letter the marker jumps away and I have to press in search box again to continue to write.
- Google Music, problem with this in stock also. If the music is not stored locally the music stop after track number 1 (wen it's supposed to continue to track number 2). Plz see attached log GM1 and GM2 (same procedure).
- Google Music, the sound was distorted/choppy. See GM3
- I had some problem with sound, DTS/DD worked after shifted to "HDMI bitstream". Is it possibly to have DTS/DD work with Plex? I got some disorted/choppy sound in SPMC also. I have attach a log (SOUND) when testing different options. Let me know if you want something specific tested (app/setting/movie).
GM1.zipGM2.zipGM3.zipSOUND.zipBeelink R89
Pioneer SC-2022
Samsung 55" LED 2012
Previous:
Minix X8-H
Minix X5
Logitech Revue
With 2.0.2 NTFS is also working but above problem is associated with drive divided into two partition: first FAT32 and second NTFS (or otherwise). In that case and present configuration in /fstab.rk30board.bootmode.emmc file VOLD choose to mount the one with FAT32 and not as owner would like that with NTFS.
This behavior can be altered by adding more directories (directions) to the path used by VOLD to find drives or rather partitions which he mounts. But in Android KitKat and with Wasser's clock like precision it would require more than few changes in about three config files and recompiling whole project especially if someone want to have info about each storage displayed in Settings->Storage page.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
thank you Wasser for your extreme effort... i really really love this rom , yet again i'm truly feeling bad because it played almost everything fine with stock player and mx player in H/W mode EXCEPT FOR MOVIES WITH DTS AUDIO (movies with dts play fine but with no audio in h/w mode).... aside from that everything else plays fine in h/w ( i mean movies with dolby digital audio )... so ;
in mx player (h/w mode) :
-movies with dts ( awesome video and no audio )
-movies with DD ( awesome video and awesome audio )
@gridlock. You didn't provide any meaningful details. What TV do you use? Is it connected directly or through some HDMI AV amplifier equipment. There is much better post on that matter in this thread. Look at #58.
I haven't got any issue with DTS playback in MX Player and HW (without +) mode through digital HDMI output (probably PCM 2.0) or analog AV connection for headphones with default sound output setting in opposition to situation described in above mentioned post.
Maybe you set audio output as HDMI bitstreem which is similar to SPDIF passthrough and it should be only used when your external audio equipment can decode DTS.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by wolfheart79 View PostI WANT TO NOW NOW MOST OF THE THINKS ARE OK ? BETTER SWITCH TO THIS ROM.
Originally posted by wolfheart79 View PostPS: GORMAR I HAVE TO ASK YOU SOMETHING ABOUT NTFS PROBLEM , WITH THIS ROM THE TORRENT WORK ?? THANK URK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
There are currently 1951 users online. 3 members and 1948 guests.
