like i as said h264, xvid was OK, i haven't check h265... but was it ok on last stock rom with mxplayer HW? i'm not sure it's related to wasser's rom....
Kikat - Wasser Firmware for Beelink R89
This issue might be connected to patched libmedia (pass-through) mentioned in the changelog which I personaly don't need or it was introduced by new RockChip SDK. I will try to "transplant" libstagefright*.so files from stock firmware to this one and see what happens.
I haven't got such an issue in stock 110k4 firmware that's why I know that HW playback is much better and fluid than HW+ in current MXPlayer on RK3288 SoC.
I would get back to stock firmware but Wasser's ROM are just to close to my preference that I can't resist them. For example: internal SD emulation on data partition, lock screen and auto sleep, power off menu, configurable luncher and I could go like this for a long time.
RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View Post... I will try to "transplant" libstagefright*.so files from stock firmware to this one and see what happens ...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by Gormar View PostI'm not exactly sure what motion enhancement in my monitor could have done this:
[ATTACH=CONFIG]9069[/ATTACH]
Below how it should look like (HW+ mode)
[ATTACH=CONFIG]9070[/ATTACH]
This is from file "hollywood-makover-8000.mkv" encoded with H.265 codec.
When I use moded XMBC from Kodi there is no problem when I use libstagefright or mediacodec video hardware acceleration mode. But in the later case I enounter FC when seeking. If you have similar problem then disable mediacodec in XMBC. Maybe I will try Google Play store XMBC but I've got suspicion that this issue is connected to moded libstagefright libraries.
Archos player was the only one out of 7 that I tried that would play a file correctly.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by no_spam_for_me View PostMaybe you should try the 'before' one http://www.freaktab.com/showthread.p...l=1#post249358
Originally posted by bluesmanuk View PostThat is very similar to the problem that I was originally having, although mine was more yellow than green.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
LED not turning red
Hello Wasser,
Great ROM!
I noticed the LED does not turn red in sleep mode. It stays blue, is it changeable
Minor bug 1: apps icon cannot be removed from launcher screen
+ I had a green screen and then color mixing for 2-3 seconds while I was trying to remove an app icon from home screen (I dragged it left-right try to find if there's an X somewhere.)
++ had the problem again for half a minute.
First it turns green, then like on the pictures.
(wasser 2.0.1)Beelink R89 PCB V3.0
Running on Finless V1.2 at the moment
Hello Wasser,we can not download: wasser-firmware-2.0.1 in china .can you upload it to freaktab or other link .thanks to you!!!
Originally posted by Hui91 View PostHello Wasser,
Great ROM!
(wasser 2.0.1)
apps icon can be removed from launcher screen, you have to move the icon at the top in the middle and when the icon becomes red, just release the button
Wasser
Originally posted by gridlock View Postwell unfortunately my beelink R89 is still suffering from the mx player's H/W decoding problem... actually , all video players , including stock , but when i reflashed the box with the latest 110k firmware , everything is working again (H/W decoding with dts and dd in all players , including mx player).....
Originally posted by Gormar View PostThis issue might be connected to patched libmedia (pass-through) mentioned in the changelog which I personaly don't need or it was introduced by new RockChip SDK. I will try to "transplant" libstagefright*.so files from stock firmware to this one and see what happens.
Wasser
Originally posted by ls2000 View PostHello Wasser,we can not download: wasser-firmware-2.0.1 in china .can you upload it to freaktab or other link .thanks to you!!!
wasser
Originally posted by Batfink32 View PostJust to say, I received my R89 today and flashed Wasser 2.1 rom. I also have the "green pixels" pattern when trying to play a video with MX Player with Hardware decoder. It also happens on the stock video player. I've flashed and wiped 3 times but it's still the same.
thanks
Wasser
Originally posted by wasser View Postcan someone reproduce the led issue? does it work for you with stock firmware?
Wasser
Launcher is not a big deal, I can switch! But the main reason I changed back to finless is the green pixels. (I tried V2.0.1, flashed with Android tools v2.3 from Finless ROM)Beelink R89 PCB V3.0
There are currently 3477 users online. 0 members and 3477 guests.
