Kikat - Wasser Firmware for Beelink R89
Originally posted by gridlock View Postthanks for the effort dear brother.... but sadly , the same old issue with the H/W decoding.
Tested BEIN SPORT app with hdmi flag to off.... i "unrooted" rom with SuperSU.
And app is NOK.. Crash at vidéo launch.
My app know device like a RK3288, not like a Nexus 10. Maybe it's a spoof trouble ?
To be continued...Last edited by roolmapool; 04 December 2014, 23:40.
To be continued...
Originally posted by roolmapool View PostNope, i mean HW ;-) i never use HW+
Originally posted by gridlock View Postwell unfortunately my beelink R89 is still suffering from the mx player's H/W decoding problem... actually , all video players , including stock , but when i reflashed the box with the latest 110k firmware , everything is working again (H/W decoding with dts and dd in all players , including mx player).....
And check about Mx codecs NEON v7 on playstore.
i never had a bad flash and i always give it more than 5 minutes to reset. the custom codec used is ARMv7 NEON... truly weird.
Originally posted by gridlock View Postthanks for the reply.... so it worked for you? i mean no more H/W decoding issue?
Try Bsplayer to see if you have same Mx issue. And stock player? it use same library codecs than Mx...
Originally posted by roolmapool View PostMxplayer HW (last version) is now OK. I checked 2/3 full HD movies H264 and Xvid movies. All is fine.
Originally posted by gridlock View Postsame issue with all players , including the stock player....
Maybe it related to your TV setup... Recent tv have a lot electronic about 'true motion'... It s so crap, you have to turn off this effect (true motion on LG tv in my case)
I'm not exactly sure what motion enhancement in my monitor could have done this:
Below how it should look like (HW+ mode)
This is from file "hollywood-makover-8000.mkv" encoded with H.265 codec.
When I use moded XMBC from Kodi there is no problem when I use libstagefright or mediacodec video hardware acceleration mode. But in the later case I enounter FC when seeking. If you have similar problem then disable mediacodec in XMBC. Maybe I will try Google Play store XMBC but I've got suspicion that this issue is connected to moded libstagefright libraries.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
There are currently 1512 users online. 1 members and 1511 guests.
