no gpu support ?? and now ?
Kikat - Wasser Firmware for Beelink R89
Hello guys. I still have the 2.0.3 version and i would like to update to 2.0.5. It is a bit of pain to wipe everything and install everything all over again. Do you have a better way to do this? Any software to do a backup of data,saves,etc?
What do you guys do? Wipe and install everything all over again?
thank you
Originally posted by Chaparro View PostHello guys. I still have the 2.0.3 version and i would like to update to 2.0.5. It is a bit of pain to wipe everything and install everything all over again. Do you have a better way to do this? Any software to do a backup of data,saves,etc?
thank you
I just use Titanium Backup to backup the apps and data and restore after flashing.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Solution to random volume muting bug.
So as you may have read, I have reported the volume randomly muting multiple times and others have confirmed it a few pages back. It seems to happen when the volume on android is at maximum level.
If you turn it down a notch from the highest level, the sound won't mute. I've tried it extensively and everytime I put it back to 100% it will eventually mute, if I lower it by pressing the volume down button once, it will never mute.
I hope it works for those who have this issue.
Originally posted by mo123Try to plug keyboard receiver into a different USB port then it will work.
Also try my keyboard patch above and see if sound doesn't mute.
sorry .
thank u.
support dts+dolby work fine , the other NO.
streaming improvement.
thank u wasser
There are currently 2918 users online. 1 members and 2917 guests.
