Kikat - Wasser Firmware for Beelink R89
If you use cachemembuffersize 0 it writes to the internal sd and causes stutters in playback.
When using default settings or a higher number it uses the internal memory which is faster.
Apps like popcorn time also writes torrents to internal sd and this causes lots of stutters.
I use Genesis with 20mb cache and works flawless.
Originally posted by Henkdevries View PostIf you use cachemembuffersize 0 it writes to the internal sd and causes stutters in playback.
Thank u , I am trying to see those instructions
stuttering loudly
Originally posted by wasser View Posti don't have the hardware to test DTS passthrough stuff. Can someone else reproduce this issue?
please test an report if passthrough DTS works
Thanks,
Wasser
I'm using your FM all ready a month. 99% all works just fine. I have Harman Kardon Home center. Beelink connected through HDMI. HD movie with DTS sound , working time to time. Some times , no problem or suddenly start stuttering loudly until I will switch of pass-through.
It will be grate if you able to fix this.
My config:
Beelink R89 with wasser-2.0.5-beelink-r89-rk3288, SPMC
I understand what you are writing but , i guess the issue is that the box or the firmware has a problem when doing two jobs at once.
Explain myself :
When i buffer the movie from Genesis lets say and watching simultaneously and lets say that i have left it buffer the half of the movie it stutters when i am watching randomly.
When i leave the movie to full buffer and then watch no stutters at all.
So as i see it perhaps you are right and if i leave alone the internal drive and tell RAM to buffer i will not have any problems , but in this case i can not buffer the full movie since the buffering size will depend on my settings .
Your settings should be ok if you have a very fast Internet spped . In my case that i can download 1mb/s on average 20mb of cache will be nothing at all while watching a movie in HD .
i will try your way but telling ram to buffer 200mb ( 600mb used RAM ) since i use the box only for Kodi .
I will report the findings after that.
Has anyone the read/write speed of the internal hard drive? Is it slow or Wasser is right about the kernel issue?
Is there a way to tell Kodi to buffer on a very fast external sd card , so to leave alone the internal drive????
BTW: zero cache isn't a good idea because you stress your nand because of all the continues read/writes (the same at torrent)...
If you want to use zero cache you should thinking about maping it to external SD
or optimize your advancedsettings.xml to use more RAM
Because the performance at the SD reader is something between >12.5 MB/s and < 25MB/s you should use a "Samsung EVO microSD 32GB" because of the fast read/writes at random....RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostBTW: zero cache isn't a good idea because you stress your nand because of all the continues read/writes (the same at torrent)...
Because the performance at the SD reader is something between >12.5 MB/s and < 25MB/s you should use a " Samsung EVO microSD 32GB" because of the fast read/writes at random....
I preferred the second option. I gave 400mb of RAM and everything works as good as possible .
It buffers a dissent amount of the movie and while buffering there are no stutters at all even in .
I think now i can enjoy the box !
LightHome launcher
I was wondering can someone be kind to compile the lighthome launcher that comes with the original firmware to wok with wasser 2.0.5 firmware and also make the xbmc shortcut to work with latest kodi release with an icon change also?
I think that the original launcher is very good .
I do not have the knowledge to do it on my own so that for i kindly request it from you guys !
ex:
Code:[COLOR=#009900][FONT=monospace][COLOR=#000000][B]<advancedsettings>[/B][/COLOR][/FONT][/COLOR] [COLOR=#009900][FONT=monospace][COLOR=#000000][B] <network>[/B][/COLOR][/FONT][/COLOR] [COLOR=#009900][FONT=monospace][COLOR=#000000][B] <buffermode>[/B][/COLOR][/FONT][/COLOR][COLOR=#000000][FONT=monospace]1[/FONT][/COLOR][COLOR=#009900][FONT=monospace][COLOR=#000000][B]</buffermode>[/B][/COLOR][/FONT][/COLOR] [COLOR=#009900][FONT=monospace][COLOR=#000000][B] <cachemembuffersize>[/B][/COLOR][/FONT][/COLOR][COLOR=#000000][FONT=monospace]157286400[/FONT][/COLOR][COLOR=#009900][FONT=monospace][COLOR=#000000][B]</cachemembuffersize>[/B][/COLOR][/FONT][/COLOR] [COLOR=#009900][FONT=monospace][COLOR=#000000][B] <readbufferfactor>[/B][/COLOR][/FONT][/COLOR][COLOR=#000000][FONT=monospace]20[/FONT][/COLOR][COLOR=#009900][FONT=monospace][COLOR=#000000][B]</readbufferfactor>[/B][/COLOR][/FONT][/COLOR] [COLOR=#009900][FONT=monospace][COLOR=#000000][B] </network>[/B][/COLOR][/FONT][/COLOR] [COLOR=#009900][FONT=monospace][COLOR=#000000][B]</advancedsettings>[/B][/COLOR][/FONT][/COLOR]
Originally posted by orionas21 View PostIf you used the second option then change in the readbufferfactor from 2.0 to 20.
ex:
Code:[COLOR=#009900][FONT=monospace][COLOR=#000000][B]<advancedsettings>[/B][/COLOR][/FONT][/COLOR] [COLOR=#009900][FONT=monospace][COLOR=#000000][B]<network>[/B][/COLOR][/FONT][/COLOR] [COLOR=#009900][FONT=monospace][COLOR=#000000][B]<buffermode>[/B][/COLOR][/FONT][/COLOR][COLOR=#000000][FONT=monospace]1[/FONT][/COLOR][COLOR=#009900][FONT=monospace][COLOR=#000000][B]</buffermode>[/B][/COLOR][/FONT][/COLOR] [COLOR=#009900][FONT=monospace][COLOR=#000000][B]<cachemembuffersize>[/B][/COLOR][/FONT][/COLOR][COLOR=#000000][FONT=monospace]157286400[/FONT][/COLOR][COLOR=#009900][FONT=monospace][COLOR=#000000][B]</cachemembuffersize>[/B][/COLOR][/FONT][/COLOR] [COLOR=#009900][FONT=monospace][COLOR=#000000][B]<readbufferfactor>[/B][/COLOR][/FONT][/COLOR][COLOR=#000000][FONT=monospace]20[/FONT][/COLOR][COLOR=#009900][FONT=monospace][COLOR=#000000][B]</readbufferfactor>[/B][/COLOR][/FONT][/COLOR] [COLOR=#009900][FONT=monospace][COLOR=#000000][B]</network>[/B][/COLOR][/FONT][/COLOR] [COLOR=#009900][FONT=monospace][COLOR=#000000][B]</advancedsettings> [/B][/COLOR][/FONT][/COLOR]
I have already done this !
Thanks a lot anyway !!
Which file should i download
Originally posted by wasser View PostHi folks,
wasser firmware 2.0.0 and wasser kodi 1.0 are available for download.
Have fun.
Wasser
1) Firmware download: http://www.freak-tab.de/wasser/wasse...r89-rk3288.zip
2) Wasser-Kodi download: http://www.freak-tab.de/wasser/wasser-kodi-1.0.apk
And can you please explain to me (Firmware download) and (Wasser-Kodi download) what is the difference between this Two Thank you very much.
or it is compulsory to download this two file 1) and 2) for my Beelink R89 in-order to update please give me some advice Thank you.
Compassion Humble
请培养慈悲心和谦逊
Best regards : Gayble
1) is the rom / firmware (Android) and 2) is the kodi version by wasser....
Why don't you want to use the newer 2.0.5 instead of the older 2.0.0?
Of course you can also use e.g. SPMC http://spmc.semperpax.com/ instead of 2)
or install them parallel...RK3288 Devices
There are currently 1944 users online. 0 members and 1944 guests.
