Kikat - Wasser Firmware for Beelink R89
I can conform the audio dropout issue but it doesn't happen very often.
It just drops from maximum to off after a period of about 45 minutes.
When dropping the level just below maximum, the problem goes away.
I have also noticed that on boot, my external sd card shows 0 bytes.
Unmounting and remounting does not resolve it, I have to physically eject and re-insert for it to be recognised correctly.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by AndreaSpooky View PostHi,
just a quick question.
I'm using stock R89 rom at the moment, and apparently I can't read multipartitioned ext drives (NTFS+FAT) since only NTFS is read.
Could someone try and do the same kind of try on this rom pls?
With the Open Hour Chameleon firmware works fine. That use 111K4 kernel for R28.
Hope Wasser can fix this problem soon.
Originally posted by wasser View Posti cannot reproduce this issue. Please give more infos how to reproduce this issue!
Wasser
2) Set Audio to max volume on Android OS
3) Let it sit overnight on the home screen. The next morning the sound will be turned all the way down on the Android OS but the mute icon won't be displayed in the upper right hand corner.
4) This just happened to me today on all 3 of my R28's with Wasser 2.0.5Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by TitoXx View PostI'm still having distorted sound with Dolby and DTS on SPMC 14.1 B1.
My Setup:
Device: Beelink R89
Rom: Wasser 2.0.5
Sound: HDMI Bitstream -> TV -> SPDIF -> Vizio 5.1 Soundbar.
- VP9 4K doesn't work
Originally posted by atombu View Postfirst of all, what a amazing ROM.
flash 2.0.5 on my Tronsmart R28 meta with Mele F10 deluxe everything works fine.
very fast and stable.
only problem is when I plug external SD card into the slot, the system will reboot itself and then keep bootloop.
anyway to slove this problem?
Hello wasser, thanks for your reply about sdcard issue... indeed, i had same issue than atombu.
I fix that with sdcard replacement... 2.05 is fine with transcend sdcard, but i had reboot issue with sandisk sdcard.
Previously in 2.03, sandisk sdcard was OK... many storage issues since 2.05, maybe a new buggy storage driver?
Thx for your work
Originally posted by wasser View Post1) could you please try to play the videos with the stock video player and see if the drops framess still happen?
Please use LAN instead Wifi
Wasser
Originally posted by roolmapool View PostSame here, you have to change sdcard brand (sandisk was NOK for me).
Thx for your work
wasser, looking forward to your OC kernel for 2.0.5
thankz
Originally posted by wasser View PostHi all,
i have uploaded the http://www.freak-tab.de/wasser/updat...-fix-2.0.5.zip which should fix the wifi issue.
Please download it and update it in recovery mode.
Howto install the update:
- download the http://www.freak-tab.de/wasser/updat...-fix-2.0.5.zip and copy it to external sdcard
- reboot device into recovery mode
- choose "apply update from external sdcard" from recovery menu
- select the update-kernel-fix-2.0.5.zip
- reboot device after the update is done.
Please report the results. Thanks
Wasser
no wifi issues with orion meta. Pro uses a different wifi module,I don't know what beelink r98 uses but if it's the same chip as the meta, I can see why it wouldn't work on the pro. Although it might be completely unrelated.
Does it at least scan the network? What happens if you try to turn wifi on through the settings on android? Error message? Crash?
There are currently 3683 users online. 0 members and 3683 guests.
