Kikat - Wasser Firmware for Beelink R89
Originally posted by balric View PostJust noticed the mute prob, will apply fix from mo123 on post #847. will let you know if it works.
I thought it did as it was days without the mute problem, but last night I was watching a 2 hour movie and it muted by itself. The only workaround for this that I've found so far is to lower the volume one level below max volume in the android OS.
Wasser can't reproduce the problem simply because it's way too random of a bug. I hope he manages to find it and fix it.
for the time being don't raise the volume level to the highest and it should never mute.
I have also a problem with HDMI passthrough on my R28 Meta v3.0. When I have the volume on android on max and play a movie(Kodi, Youtube etc..). The passthrough is dropping out and in every 10-30s, however if I lower the volume one step, the problem kicks in one time every hour. It doesn't matter if the audio is PCM, DD or DTS.
Hope you will figure this out wasser
With this said, the ROM is pretty stable and good. When I lower the volume one level, videoplayback with the new SPMC 14.1 is very smooth and with working DD and DTS passthrough.
I used for two days a modified version of your rom for HTC and compatible AP6330...
Great work!
Thank you Wasser for this work!
I try a lot applications and for videos, I think Rockplayer2 is the best one for 4k h265 on rk3288 too (I allready use it on all my devices)...I try Sintel and Big Buck Bunny videos and there's no lag (as in SPMC) except small ones when downloading something in background.
It's even a little better than videoplayer from your rom...
I'm still looking for a great audio player with no stuttering when listening music during web browsing
NEW - Wasser Firmware V2.0.4 for Beelink R89/Tronsmart R28
Originally posted by Mario023 View PostI have logitech c270 .
I tried skype from xda with no luck
You don't have image at all?
There are currently 3921 users online. 1 members and 3920 guests.
