Kikat - Wasser Firmware for Beelink R89
Use MXPlayer HW mode not HW+ !
From my personal experience MXPlayer on RK3288 and RK3188 works better in HW mode than HW+. This "plus" has some power over people (myself incuded) and they think that playback is better than without it.
Even better. In HW mode MXPlayer can HARDWARE decode DTS audio stream on RK3288 or at least without "Custom Codec" downloaded which is "undocumented" feature.Last edited by Gormar; 08 December 2014, 22:45.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by wasser View PostHi Folks
i don't think it's difficult to test LED and and i don't think it breaks your device by this testing. It doesn't take time, just press power button and see if led is red or blue! it's all
Wasser
Thanks.
IR Remote from Tronsmart R28
Will I be able to use the stock IR remote on a Tronsmart R28 Meta with this ROM?
Thanks!
Cheers,
-SB---------------------------------------
Currently using U-BOX R89 with mo123 v1.6.
Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
Pipo M9S -- CrewRKTab custom rooted 4.4.2
RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
Stock remote
If it works with stock firmware (i.e. 110k4) then certainly yes.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Great, thanks! I'm setting up this r28 for a client and am considering using this ROM. Just wanted to be sure.
Cheers,
H/W decoding
Hi All,
I just received my R89 and am having problems with hardware decoding. I've tried the stock rom and different XBMC builds (stock, XBMC 13.2 and Kodi) but have the same stutter problems.
I've been reading this thread and flashed this rom to the device. XBMC 13.2, Kodi and Wasser XBMC still stutter with hardware decoding on but work better with it off (software decoding). I've ended up on SPMC with hardware decoding off which gives me the best result.
I have a 10/100 ethernet connection to my Synology NAS which stores all my content. Previously was using a Intel NUC and XBMC with no issues at all.
I have stutter and audio sync problems paying normal series files (300mb in size) in avi, mp4 and mkv formats. 720p movies (File size <2GB - YIFY) stutter too with h/w decoding on.
Any ideas what might be the problem? Bum box?
XMBC HW decode MediaCoder or Libstagefright.
I don't often use XMBC especially for streamed content but I know that it is use two different video hardware decode modes. First is MediaCoder and second is libstagefright. This order is not random. Try to disable one of them in Settings->Video (advanced)->Acceleration menu and watch what happens.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by wasser View PostHi Folks,
wasser firmware 2.0.2 is released. Please take a look at the first post to get more infos about new release.
Have fun.
Wasser
The download link doesn't seem to be working at the moment but as soon as it is, I'll install and test.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
There are currently 2613 users online. 1 members and 2612 guests.
