but don't know if it works on this ROM, works for most RK3288 devices. Just copy unzipped update.zip to flash drive and insert to your device to update and root.
Kikat - Wasser Firmware for Beelink R89
Originally posted by Gilgamesh View Post
Originally posted by mo123 View PostYou can also root with http://www.freaktab.com/showthread.p...8-EZ-Root-Tool
You, Wasser, Bob and Leolas should join forces as it seems to me that you all have the ability to produce cracking custom ROM's for these devices right now.
Originally posted by martijn156 View PostAlso tried this one but unforunatly doesn't work either.....
If not, I think there is a problem at the connection between the box (at OTG (micro USB port)) and the PC (at USB) which you/we have to fix first...
You can also try to connect the box and the PC while you are at android... you have to check if 'Settings -> [DEVICE] -> USB -> Connect to PC' is checked/selected...
Maybe try to use another USB cable...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostDoes you PC (running at W8.1) recognise the device, maybe as unknown?
Thanks a lot guys!!
R: NEW - Wasser Firmware V2.0.2 for Beelink R89/Tronsmart R28
Originally posted by Gilgamesh View Postis it any point with a overclocked kernel? is 2GHz the max freq this SoC can handle or is it possible more than that? if not I don't see how 200MHz extra would help so much? ok if it was 300-500MHz.
Tapatalked from my GALAXY S5
I mean only ddr and gpu...
Sv: NEW - Wasser Firmware V2.0.2 for Beelink R89/Tronsmart R28
Originally posted by Catadarius View PostLeolas made an Oc kernel only for the DDR and GPU....and you can notice the difference.
There are currently 2767 users online. 0 members and 2767 guests.
