If you power on (plug in PSU) while pressing the microSwitch WITHOUT otg connected to pc it will start to recovery, if WITH otg connected to pc it will start to bootloader (for flashing)...
Kikat - Wasser Firmware for Beelink R89
Originally posted by Mirze View Post
If you power on (plug in PSU) while pressing the microSwitch WITHOUT otg connected to pc it will start to recovery, if WITH otg connected to pc it will start to bootloader (for flashing)...RK3288 Devices
- Overview BOX (LINK !)
I'm sorry... I do NOT understand how to instal the Wasser ROM.
I tryed to help myself tith the site http://www.freaktab.com/showthread.p...-Tools-release , but it didn't go...
Please assistance
Firmware update procedure
@aundp. How far you've come?
Originally posted by oman View PostHow to Update:
1.Install Driver(Release_DriverAssitant),refer to the next post;
2.Open AndroidTool_Release_v2.3, then load the ROM;
3.Plug in PSU(Power supply unit),and push and hold the button in the AV hole,then plug-in the USB OTG cable..
4. After the tool show up 'Found One LOADER Device', click 'Upgrade'.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Firmware update procedure [comprehensive]
Originally posted by aundp View PostI don't succeed to load the firmware...
By the way I found even better guide how to use this tool. You can read more here.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Question: add support for no wake up on mouse movement, enable it by default
Hi folks.
Can someone explain to me that how to change the status of the wake up on mouse movement?
In wasser firmware the wake up on mouse movement is disabled by default.
It might be very convenient for me to turn ON/OFF the wake up on mouse movement with a simple toggle switch in settings menu.
USB device wakeup cause system freeze.
@polas. I can not find that option right now. Maybe it was removed or forgoten by Wasser but at the and it doesn't matter. You should be able to wake up you device with mouse click. But there we encounter quite big drawback of these RK3288 devices because when you put them to sleep then it disable USB ports and any interaction with connected devices end in system freeze. USB wakeup is f...ed up.
Rock Chip do you have any good engineers ?
1. RK3288 blocked to 1,6HMz max but advertised as 1,8MHz or even 2.0GHz.
2. Video playback issues going back up to RK3188 desing.
3. And even USB suspend is broken on all tested by me firmwares(stock 110k4, wasser 2.0.x).
4. DDR memory speed set to 428MHz when nominal is 800MHz (DDR3-1600 CL11 - Mira).RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
There are currently 43112 users online. 0 members and 43112 guests.
