Kikat - Wasser Firmware for Beelink R89
    Sv: NEW - Wasser Firmware V2.0.2 for Beelink R89/Tronsmart R28
    Originally posted by Catadarius View Post
    I do not play with the box.....so no heat problem.
    same here, I just bought it for watching movies, I guess no need for OC then? or would it help?
    Tapatalked from my GALAXY S5
      How can i switch back to normal device id? it's now nexus 10 and the app i want to install is not compatible. it was compatible on stock rom (110)
        Its all in the build.prop file at the root of the system. Find a root explorer and take a look in the text file.
          Install Instructions
          Hello All,
          Thanks for your work on this ROM.
          Are there install instructions for this ROM? I looked thru the tread and did not see any. It looks like it could be similar to installing one of Bobs ROMs but I wasn't sure.
          Thanks for any help.
          Brad
            Re: NEW - Wasser Firmware V2.0.2 for Beelink R89/Tronsmart R28
            Never mind, found the apk but drm protected streams still not working as it should be. It's giving me green picture (sound works great)
            Flashed back stock v110 where it works. I'll prefer wasser rom but I'll wait for newer build.
              Originally posted by BP-isMe View Post
              Hello All,
              Brad
              To flash this rom just follow the guide from first post here:
              Beelink R89/UBOX ROM/Tools release
                Thank You
                I found the install instructions in your link...should be no problem.
                Brad
                  I just installed the non-beta 2.0.2
                  HDMI Pass through still doesn't work for me (((((
                  I tried with Wasser Kodi.
                  Well, with MX Player it seems to work mostly, but there are some little stops every couple of minutes.
                  If this HDMI pass through issue gets solved, I'll be one of the happiest men on Earth.
                    Upgraded my Beelink R89 last night to Wasser 2.0.2, anyone have any suggestions on optimizations for XMBC? Installing SPMC v13.3.3 last night (via googlestore) resulted in lots of dropped frames of a 1080p movie so much so it was unwatchable
                    Thanks.
                      Download Wasser-Kodi player from the bottom of the first post. http://www.freak-tab.de/wasser/wasser-kodi-1.0.apk
                      RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
                        Thanks for the swift reply. I completely missed that portion of his post! I will install this apk this evening and let everyone know how I get on, do you have any pointers on how install this .apk via android?
                        Thanks again.
                          There is also a new version of spmc optimized for rk3288 (13.4.0) here :
                            http://spmc.semperpax.com
                            Thanks for the pointer!
                            Its getting confusing now thou, which version is preferred, Wasser's or Yoyings SPMC?
                            On the face of it SPMC v13.4.0 is only a few days old so could be less buggy and stable?
                            Thanks again.
                              You can use / install Kodi and SPMC parallel, and I wouldn't wonder if wasser version too...
                              RK3288 Devices
                              - Overview BOX (LINK !)
                                i just got beelink 16gb version .dont work stock remote on stock rom and dont work remote on wasser rom,if somone have 16gb version beelink i must to know if that remote work on 110k4 or on this rom
