Can this firmware play Youtube videos from Google app in 1080p mode?
Kikat - Wasser Firmware for Beelink R89
Youtube 1080p?
Can this firmware play Youtube videos from Google app in 1080p mode?RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by gffmac View Post
Also get audio sync issues, trying to adjust audio offset never seems to get it right.
(HDMI pass through, Dolby Digital and DTS, too)
Originally posted by Gormar View PostCan this firmware play Youtube videos from Google app in 1080p mode?
Wasser
Originally posted by drAstic View PostI also have the audio sync issue (R89) I tried to adjust the delay on my amplifier, as well as on SPMC, but delays seem to vary from time to time.
Wasser
Originally posted by gridlock View Postsadly the same issue with DTS audio ( stock and mx player ) with spdif passthrough set up .......
Wasser
Originally posted by el_easy View Post(Q) wasser when you're coming from v2.0.2 and flash v2.0.3 . Will I lose all my apps? Thanks
Wasser
Originally posted by MbTsM View Postflash via recovery ?? 2.2 to 2.3
Wasser
Originally posted by bluesmanuk View PostFlashed 2.0.3 and tested as before and all works well for me
The only two things that I note are that my USB flash drive is still continually being accessed and Youtube cannot play 1080p, 720p being the maximum.
Originally posted by wasser View Postit's not fixed in 2.0.3. It's on my todo list. If someone knows how to make 1080p working in youtube, please let me know!
Wasser
There are some very popular tablets and phones out there that had the ability and then it disappeared with new updates.
There were some suggestions that it only works with Kitkat devices when the build is set to 4.4.2 but this change works for some and not others.
1440p has started to appear on some devices.
I suspect that you may end up going round in circles trying to fix this, when a new update may well enable it automatically.
The only thought I have is to perhaps try spoofing as a different device that is known to be able to support the resolution.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by wasser View Posti don't understand your issue "my USB flash drive is still continually being accessed". Could you please give more infos sothat i can understand?
It makes me wonder whether this could shorten the life of the drive.
I'm going to try disabling background processes one by one to see if I can find what may be causing this.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Please support both Tronsmart Remote Control Versions
first thank you very much for your work. Wasser Firmware is a big step forward for me.
There is just one thing left. Tronsmart R28 Users, like me, have a problem with the remote control. Tronsmart released two hardware versions. The first one was for the beta users (108K4 & 109K4 Stock Firmware). The second was introduced with the release of 110K4 Stock Firmware (Tronsmart exclude the support for the beta Remote in this fw, not nice for beta users).
Could you please add both Remote Versions to your Firmware? At the moment, only the old version seems to work. It would be cool to support both versions. Tronsmart missed it, it is possible for you?
The remote seems to be part of kernel.
ro.sf.lcd_density=240 to 200
Originally posted by wasser View Postyes, you have to make backup before
Wasser
@Wasser Thanks once again!!..
I have SONY 36 Inch TV on Wasser version 2.0.2 / 2.0.3 screen resolution is too big on my TV screen. I edited build.prop from ro.sf.lcd_density=240 to 200 using Build Prop Editor, but didn't work..Am i doing anything wrong?-Chromecast with Google TV
- Android Q Android 10
Originally posted by bluesmanuk View PostWhen a USB flash drive is inserted, even when not in use, the light flashes on it continuously that indicates that some process is using it all of the time.
Originally posted by bluesmanuk View PostI carried out a lot of searching regarding this problem and it seems that Google is messing around with the youtube app.
"W/OMXNodeInstance( 5493): OMX_GetExtensionIndex OMX.google.android.index.prepareForAdaptivePlaybac k failed"
Originally posted by Gilgamesh View Posthave you guys tried Viral app and see if 1080p works there?
Proofs:
1. Viral Lite supposed 1080p mode
2. Chrome Browser with AVC stream 1080p playback (Use Agent spoofed as Windows XP). It is similar fix as in youtube player and Android 4.4.2.
P.S. Sorry but FreakTab recompressed these images to much for my liking. There are originals: https://drive.google.com/folderview?...UE&usp=sharingRK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
There are currently 3076 users online. 1 members and 3075 guests.
