Kikat - Wasser Firmware for Beelink R89
Originally posted by maxxxy View Postthank you
and for install the root.zip ????
root.zip or unroot.zip can only installed in recovery mode
Wasser
Originally posted by wolfheart79 View PostHello.
With 3188 box, with your custom rom Wasser 1.04 there is no problem in playing from torrents (xbmctorrent to be precise). Is it possible to do the same for the 3288 boxes? Because currently the playing stops after some 15-30 minutes with a crash of the above script. This happens only in Android and not other platforms, so the script works and we can ignore it. I have noticed that the time depends on movie quality and therefore some cache on disk. When this reaches 2GB it crashes and this happens in all roms, stock roms of boxes included. Only with your custom rom this does not happen, all works properly. So, is it possible to determine what is different in Wasser 1.04 on 3188, with current Wasser 2.0.2 on 3288 (like belink).
Thank you.
Wasser
Originally posted by bajann View Posti just got beelink 16gb version .dont work stock remote on stock rom and dont work remote on wasser rom,if somone have 16gb version beelink i must to know if that remote work on 110k4 or on this rom
Wasser
Originally posted by Gilgamesh View Post
if someone wants to unroot the device, just download the unroot.zip , put it to externel sdcard and reboot device into recovery mode. Choose update from external card and select unroot.zip and reboot device if update process is done.
Wasser
Originally posted by Catadarius View PostWasser...very good work.
Any chance of an overclocked kernel.
You promise one week ago, and i want to know if it still an priority.
Wasser
Originally posted by bluesmanuk View PostOr if you already have a working rooted ROM installed, install the Petrus Reboot app and use that to reboot to bootloader, where you can have the OTG cable connected before you start and not have to fiddle about with anything.
my firmware already has this ability. Just press the powerbutton and select "boot into boatloader mode"
Wasser
Originally posted by drAstic View PostHi,
I just installed the non-beta 2.0.2
HDMI Pass through still doesn't work for me(((((
I tried with Wasser Kodi.
Well, with MX Player it seems to work mostly, but there are some little stops every couple of minutes.
If this HDMI pass through issue gets solved, I'll be one of the happiest men on Earth.
Wasser
Originally posted by bluesmanuk View PostFlashed the ROM and done some testing.
External SD card write is fixed.
FakeID vulnerability still requires manual patching.
At the top of the notification tray there is usually an indicator with 3 lines that you click to clear the entries from the drop down list. This is no longer present.
Videos play as perfectly as they can at this time and the same as with the 2.0.2 beta.
Everything else, just as before and no issues for me.
Nice to know what one of the PCB changes was between 2 and 3 with regards to the LED not having any form of control on the original.
Wasser
Originally posted by wasser View PostHi folks,
Wasser Firmware 2.0.3 is released, please take a look at my first post to get more infos about the new version.
Please don't forget to report your results, feedbacks are very important for me.
Have Fun!
Wasser
dts work
dts hd work
dloby work
SPMC last one
thank you
There are currently 4076 users online. 1 members and 4075 guests.
