Kikat - Wasser Firmware for Beelink R89
Originally posted by mslr75 View Postyes great firmwareonly wifi dont work on my Beelink R89/UBOX
Hope it will be fix on the next patch
Regards
Marc
update-kernel-fix-2.0.5.zip fixes the wifi issue
Hi all,
i have uploaded the http://www.freak-tab.de/wasser/updat...-fix-2.0.5.zip which should fix the wifi issue.
Please download it and update it in recovery mode.
Howto install the update:
- download the http://www.freak-tab.de/wasser/updat...-fix-2.0.5.zip and copy it to external sdcard
- reboot device into recovery mode
- choose "apply update from external sdcard" from recovery menu
- select the update-kernel-fix-2.0.5.zip
- reboot device after the update is done.
Please report the results. Thanks
Wasser
Originally posted by petrosy View PostCan I use the OC kernels on the stock firmware?
Wasser
Originally posted by wolfheart79 View PostI have install 2.0.5 and the sound go mute , keyboard Ri24 its go crazy , sticky keys ,repeat keys I don t understand how its possible this option that work in old rom , in new rom have start not to work ??!!!
Wasser
Originally posted by theeze View PostSo as you may have read, I have reported the volume randomly muting multiple times and others have confirmed it a few pages back. It seems to happen when the volume on android is at maximum level.
If you turn it down a notch from the highest level, the sound won't mute. I've tried it extensively and everytime I put it back to 100% it will eventually mute, if I lower it by pressing the volume down button once, it will never mute.
I hope it works for those who have this issue.
Wasser
Originally posted by Gormar View Post@Henkdevries. Did you check if "Stay awake" in "Developer options" isn't set? Besides from my experience I know that sleep isn't stable in these devices right now. Waking up device can sometimes go into reboot
Wasser
Originally posted by roolmapool View PostSame... you have to remove your sdcard, and firmware will boot.
I use my sdcard with usb adaptater with 2.05... i m sure wasser will repair this issue
If it's the case you have to cleanup the sdcard with
dd if=/dev/zero of=/dev/[yoursdcard] count=1000
Wasser
Originally posted by wasser View Posti cannot reproduce this issue. Please give more infos how to reproduce this issue!
Wasser
If it does happen again, I'll be sure to make extensive testing before I share the info. I'm really enjoying your rom.
Thanks again!
Originally posted by BTR11 View PostI had updated from 2.0.4a to 2.0.5 but the streaming video playback on SPMC 14.1 beta1 and Kodi 15 nightly is not good, with many drops frames in some occasions and in other with skip frame depending on the type of content and resolution; using your recommended setting Libstagefright & mediacodec "On"; I had tried different status for the hardware accel codecs but none of them produce a smooth streaming playback on 2.0.5. However looks like the WiFi performance is a little better on 2.0.5, I had to revert back to 2.0.4a because a better streaming playback is required by my usage of R89.
What means in your rom "use.video.overlay=2" instead of value set to "1" or set to "0"; Is this line on build.prop required?.
As well I had noted on 2.0.5 that CPU governor set to "Performance" is not working, hang/freeze and crash the system and revert back automatically to "interactive"; not sure if this is a problem on your Rom or it´s a RK3288 uncompatibility prob; I don´t remember well but I think I can use the CPU Governor set to "performance" on 111K Firmware. I use normally to do this "No-frills CPU" app. Thanks.
Please use LAN instead Wifi
2) use.video.overlay=2 is required for rockchip player.
3) i will check CPU governor
Wasser
Originally posted by theeze View PostI beilieve it only happens randomly with a keyboard connected. Im using the k400. I've applied a fix from @mo123 that he shared and never had this issue again. I can't reproduce it.
Thanks again!
Wasser
Wasser
external SD card issue
first of all, what a amazing ROM.
flash 2.0.5 on my Tronsmart R28 meta with Mele F10 deluxe everything works fine.
very fast and stable.
only problem is when I plug external SD card into the slot, the system will reboot itself and then keep bootloop.
anyway to slove this problem?
Originally posted by wasser View Posti have some usb air mouses and all work fine for me on 2.0.5 firmwafre. Could you please give more infos how i can reproduce this problem?
Wasser
thank u
There are currently 2190 users online. 2 members and 2188 guests.
