Thanks Wasser but Still no sound over HDMI with V2.0.5 , same probs as V2.0.4a, reverted back to V2.0.3 again only one working with sound for me.
Kikat - Wasser Firmware for Beelink R89
Hi wasser,
thanx for your great rom. I'm using actual 2.0.3 but i would try a newer one.
At the moment i can't get your rom working with twrp recovery
Is it possible to support twrp and deliver updates as twrp zip ?
I think then more ppl will test the newer firmwares fast because there is always a fast way back to our good working backup.
best regards,
Thomas
best regards,
Thomas
can you pls tell me how to get twrp working with wasser firmware ?
i tried flashify and then i could not boot into twrp recovery
and the restored stock recovery with flashify and that recovery worked again but no twrp
Is there another way to get twrp working with wasser firmware ?
Which androidtool do you mean ?
Originally posted by FunThomas View Postcan you pls tell me how to get twrp working with wasser firmware ?
Sound is working over HDMI wasser 2.0.4a!!
Originally posted by theeze View PostHey Wasser, I`ve just received my R28 Orion Meta...first thing I did was install your latest rom.
As I expected...there was no sound across the board. I did manage to fix it... First I tried playing with the sound settings in Android...going from default to bitstream and back to default.
Still no sound...So I decided to reboot. Again no sound...but I did notice that the volume was muted when I accidentally hit the volume button on my k400 keyboard.
Sound works on 2.04a now. I`ve hooked it up to different televisions and I still get sound.
Great rom...
I hope it works for others as well.
Any ideas how to get the remote working for the r28? or is that on the to-do list?
Thanks again for this rom.
Good luck!!
Ubox R89 couldn't load 2.0.5 firmware??
Originally posted by wasser View PostHi all,
wasser firmware v2.0.5 is released, For more infos please take a look at the first post.
feedback is very important, please report the results. thanks!
Have fun!
Wasser
Thanks again for your effort for making these great roms, unfortunatly i tried over 4 times loading this firmwareversion (2.0.5) with rkbatchtool, also tried androidtool to flash the firmware,
But the wasser bootlogo is freezing after couple of minutes and then nothing happens. Also the bootlogo is stutering wile loading the firmware, and with the other roms no problems att all.
So back to 2.0.4A (with audio over HDMI)
Originally posted by martijn156 View PostSound is now working over HDMI with 2.0.4a, i pressed the volume button of the R89 player, on the right side of the volume bar there is a small setting icon. Just open the volume setting icon (with mouse) and swipe both of the volume bars to the right. Thats it!! Audio setting in android menu is default audio.
Good luck!!
Yeah, it's basically a bug or a foresight. The firmware comes with the volume level all the way down which basically mutes android.
I tried replicating it just to be sure and it works everytime.
I use my sdcard with usb adaptater with 2.05... i m sure wasser will repair this issue
There are currently 3236 users online. 0 members and 3236 guests.
