Wasser
Kikat - Wasser Firmware for Beelink R89
Originally posted by gismo112 View PostI have a Problem with the 2.04:
No Sound over HDMI.
Nothing with Stockplayer, MX Player, Kodi or SPMC (13.4, 14.0 Beta 2)
With the 111k Rom / Wasser 2.03 is all good.
(Thanks Wasser for your great Work with the ROM“s)
Originally posted by runonur View PostYou must restart.. it's working..
Back to the Orig. 111k, all good, back to wasser 2.0.3 all good.
Updated my Beelink 3288 to Wasser v2.0.4a earlier, installed SPMC 14.1 beta 1. (spmc link)
For me micro-stuttering during mkv video playback was bad enough to be unwatchable, on the face of it things to have gotten tonnes better with this f/w and ver of SPMC, I have spotted one or two stutters (might be my imagination) but tonnes better.
Many thanks Wasser keep up the good work!
Originally posted by gismo112 View PostNo Chance. I change the HDMI-Cable for testing, problem the same.
Wasser
Originally posted by manc View PostUpdated my Beelink 3288 to Wasser v2.0.4a earlier, installed SPMC 14.1 beta.
Wasser
Thanks for the tutorial. I am fairly new to Android OS. I will definitely learn from this.
Originally posted by Gormar View Post@duckymcse. Why bother with Windows PC when you can write these images directly from rooted Android BOX.
Take 1:
Steps:
1. Install "Tincore QuickFlasher" from Google Play Store.
2. Downloaded kernel update ZIP archive.
3. Rename downloaded file to something which ends with "_quickflasher.zip" (i.e. kernel_upd_quickflasher.zip).
4. Move this file to /sdcard/quickflasher directory.
5. Run Tincore QuickFlasher.
6. Select Device as "RockChip Universal".
7. Select Package with name you chosen is step 2.
8. Confirm destruction of your device.
I personaly preffer do do this by hand but this will demand physical keyboard.
Take 2:
Steps:
1. If you don't have terminal application install Terminal Emulator from Google Play Store.
2. Download updated kernel and resource ZIP archive.
3. Extract kernel.img and resource.img from update-kernel-fix-2.0.4.zip with ES File Explorer Archiver to some known location. i.e /sdcard/Download/kernel_upd/
4. Open Terminal Emulator and enter super user permissions: su.
5. Change current directory to where you have unpacked kernel.img and resource.img files. If you followed this tutorial it should be:
cd /sdcard/Download/kernel_upd
6. Write these files to corresponding partition on your intarnal flash memory:
dd if=kernel.img of=/dev/block/mtd/by-name/kernel
dd if=resource.img of=/dev/block/mtd/by-name/resource
I updated to 2.04a. Tried YouTube and it crashed within a minute of video playback.
I went to Setting --> Apps --> YouTube and "clear data".
So far, I watched YouTube for over 15 minutes and no crashes.
Not sure if it is coincidence or the "clear data" does the trick.
The box did reboot itself after the crashed. Maybe it just need a reboot.
Back to the Orig. 111k, all good, back to wasser 2.0.3 all good.Originally posted by wasser View Postit's fixed in 2.0.4a. please download and flash it again.
Wasser
Sry, the Problem is not fix for me in 2.0.4a. No Sound over HDMI
Can this come with the CEC-Support and is the HDMI-CEC-Support in Kernel or in System ?
Greets Gismo
There are currently 2580 users online. 2 members and 2578 guests.
