Kikat - Wasser Firmware for Beelink R89
Originally posted by amclean123 View PostI had the same problem earlier today. This is the short story that worked for both of my RK3288.
One note you might want to make sure the firmware below works with your UBOX or are comfortable reinstalling the original firmware.
Install this ROM http://www.freak-tab.de/wasser/wasse...r89-rk3288.zip
Install this player http://www.semperpax.be/owncloud/pub...&id=OauuYHwjoc
don't change any settings and see how it plays. It should play all non interlaced H264 content very well.
Sorry for disurb ...
I've flashed that firmware now, works good, i've reduct the problem of little jerky, but remained few little jerky too. Is possible a lan problem? I use SPMC Kodi dowloaded by your link but not use NFS for file sharing.
What firmware do you have before flash wasser 2.0.3? (i'm started Finless 1.2)
Wasser firmware overwrite resource.img and kernel.img or leave that file has you have by last firmware?
Do you think I must flash update_R89_111k4110_1219.img and after wasser 2.0.3?
Have you tried HPH 1.4 by mo123?
thanks in advance
Originally posted by Luxilon View Post1. XFINITY TV GO app/ESPN
2. Wireleess kkeyboard/mouse - keyys reppeating even with OTGpoort
3. xxbmc
4. PPLEX
5. NETFLIIX HD
66. Audio
some nice mproovements (minor) over 1100k44, yet time is spent on overclockingg????????
Code:/system/bin/iptables -F bw_INPUT /system/bin/iptables -F bw_OUTPUT
Code:root@rk3288:/etc/init.d # sh fixshutter sh fixshutter iptables: No chain/target/match by that name. iptables: No chain/target/match by that name. root@rk3288:/etc/init.d # cat fixshutter cat fixshutter #!/system/bin/sh iptables -F bw_INPUT iptables -F bw_OUTPUT echo init.d is working >> /mnt/internal_sd/initdsupport.txt root@rk3288:/etc/init.d # iptables -L bw_OUTPUT iptables -L bw_OUTPUT Chain bw_OUTPUT (1 references) target prot opt source destination all -- anywhere anywhere ! quota globalAlert: 2097152 bytes all -- anywhere anywhere owner socket exists root@rk3288:/etc/init.d # iptables -L bw_INPUT iptables -L bw_INPUT Chain bw_INPUT (1 references) target prot opt source destination all -- anywhere anywhere ! quota globalAlert: 2097152 bytes all -- anywhere anywhere owner socket exists root@rk3288:/etc/init.d # iptables -F bw_INPUT iptables -F bw_INPUT root@rk3288:/etc/init.d # iptables -F bw_OUTPUT iptables -F bw_OUTPUT root@rk3288:/etc/init.d # iptables -L bw_OUTPUT iptables -L bw_OUTPUT Chain bw_OUTPUT (1 references) target prot opt source destination root@rk3288:/etc/init.d # iptables -L bw_INPUT iptables -L bw_INPUT Chain bw_INPUT (1 references) target prot opt source destination root@rk3288:/etc/init.d #
Originally posted by hueb_s View PostInclude full path to iptables binary in script.
in your script. I haven't seen that. An have you set execute rights on the file?Beelink R89 2/16GB Version PCB 3.0, Stock Firmware 111K4110_1219, SPMC 14.1
Input: Wireless Logitech K340 Keyboard & M505 Mouse, Output: Philips 42PFL7404H/12
Originally posted by WarSpaz View Postdo i have to change this every time i startup the box or does it work after i've done it once?Beelink R89 2/16GB Version PCB 3.0, Stock Firmware 111K4110_1219, SPMC 14.1
Originally posted by vanzylst View PostGood news people, I've found a software-only fix/workaround to the micro stutter problem
Just put the following in your init.d config file (or you can run it from the command line):
The culprit seems to be the following iptables rules:
Code:Chain bw_INPUT (1 references) pkts bytes target prot opt in out source destination 3162K 12G all -- * * 0.0.0.0/0 0.0.0.0/0 ! quota globalAlert: 2097152 bytes 7279K 57G all -- * * 0.0.0.0/0 0.0.0.0/0 owner socket exists Chain bw_OUTPUT (1 references) pkts bytes target prot opt in out source destination 1809K 113M all -- * * 0.0.0.0/0 0.0.0.0/0 ! quota globalAlert: 2097152 bytes 5369K 389M all -- * * 0.0.0.0/0 0.0.0.0/0 owner socket exists
So just delete those rules and voilĂ ! Micro stutters gone...
Hope this works for you as well, let me know.
Cheers
There are currently 2253 users online. 1 members and 2252 guests.
