I die not do that, but only did update the driver
Kikat - Wasser Firmware for Beelink R89
Originally posted by digitalriver View PostAnd always get system reboot on YouTube.....
Hi wasser,
thanks for the new firmware. I tested it. my problem is still the same as described here:
Beeing in playstore the picture changes all half minutes from right to wrong and back. In beelinks latest stock firmware 111k4, this picture-error isn't available. In your latest firmware 2.0.3 i had to watch about half an hour until this error is shown.
Perhaps you can have a look at this please?
playback with spmc 13.4 over ethernet works fine, no micro stutters till now with no extra iptable rules set.Last edited by ChiefWiggum; 17 January 2015, 11:42.Beelink R89 2/16GB Version PCB 3.0, Stock Firmware 111K4110_1219, SPMC 14.1
Input: Wireless Logitech K340 Keyboard & M505 Mouse, Output: Philips 42PFL7404H/12
hdmi virtual switch
Originally posted by wasser View PostYou don't need this tool in my fw. In my fw you can change it in build.prop
Start from this point I ask nicely wasser to take a look at this combo to fix bluetooth and maybe power button . There is waste of time to fix something if something else works flawlessly .
hdmi virtual switch
Originally posted by mo123Have you tried this
If the app still doesn't work, you will have to ask Openhour for help since you are using their firmware and not Beelink or Wasser v2.0.4.
hdmi virtual switch
Originally posted by mghome59 View PostStart from this point I ask nicely wasser to take a look at this combo to fix bluetooth and maybe power button . There is waste of time to fix something if something else works flawlessly .
Originally posted by Humpty Dumpty View PostBluetooth and power button are no problem for me. I will try to fix this for myself. It could not be difficult to change rights for a file at boot time ;-)
That will be nice to have a good working combo ... I have tryed my self but I have to say I`m not good enought
Special kernel for Firefly
Hi Wasser,
i'd like to know if it would be possible for you to compile a kernel with modded gmac part in DTS file ?
here is the change the rx delay
tx_delay = <0x30>;
rx_delay = <0x16>;
those mods repair LAN part on firefly. When i flash my compiled kernel after installing your image it doesn't boot and i dont know why
Thank you for return
Pacopad
HEX editor FTW
@pacopad. If you want to change just one (or even more) value in resource.img file then use HEX editor. There is no need to compile DTS (Device Tree Source).
Just now I'm using Wasser 2.0.3 firmware and I don't have his newer version "decomposed" but in resource.img I can easly find "eth@ff290000" node when searching for ASCII strings. Decompiled structure looks like this:
Code:eth@ff290000 { compatible = "rockchip,rk3288-gmac"; reg = <0xff290000 0x10000>; interrupts = <0x0 0x1b 0x4>; interrupt-names = "macirq"; clocks = <0x67 0x79 0x0 0x79 0x1 0x79 0x2 0x79 0x3 0x7b 0x0 0x7b 0x1>; clock-names = "clk_mac", "mac_clk_rx", "mac_clk_tx", "clk_mac_ref", "clk_mac_refout", "aclk_mac", "pclk_mac"; phy-mode = "rgmii"; pinctrl-names = "default"; pinctrl-0 = <0xe6 0xe7 0xe8 0xe9>; reset-gpio = <0x5 0x8 0x1>; clock_in_out = "input"; tx_delay = <0x30>; rx_delay = <0x10>; };
00 00 00 03 00 00 00 04 00 00 09 fe 00 00 00 30 00 00 00 03 00 00 00 04 00 00 0a 07 00 00 00 10
00 00 00 02 00 00 00 01 72 6f 63 6b 63 68 69 70 2d 74 73 70 40 30 78 66 66 34 32 30 30 30 30 00
Where "00 00 00 03" mean new field, "00 00 00 04" it its size (4bytes), "00 00 09 fe" it is a byte offset of that field name stored at the and of DTB file (it will probably start with "#address-cells" in ASCII). In this case it is "tx_delay" and "00 00 00 30" is this field value. Next "00 00 00 03" opens last filed in this node and it is "rx_delay". "00 00 00 02" after field definition "closes" current node and "00 00 00 01" opens new one. In this case "rockchip-tsp@0xff420000".
Then you will only change "00 00 00 10" before "00 00 00 02" to "00 00 00 16" and save the file. After that "flash" it into the box.
All can be done from within Android. Just to flash use "dd" tool and write moded file into "/dev/block/mtd/by-name/resource" partition.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Hi Gormar,
thank you for advice, i'll try that
Best regards
Pacopad
Originally posted by Gormar View Post@pacopad. If you want to change just one (or even more) value in resource.img file then use HEX editor. There is no need to compile DTS (Device Tree Source).
There are currently 2389 users online. 1 members and 2388 guests.
