Kikat - Wasser Firmware for Beelink R89
    Originally posted by heiko123 View Post
    Delete the cache from skype and all is fine.
    Gesendet von meinem SM-P905 mit Tapatalk 2
    From android settings?
    I tried did not help.
      Another Mirror if someone needs it.
        Not getting any sound through HDMI. Is this normal??? Using denon receiver.
          I've got no sound through HDMI after update either, was working fine on v2.0.3
            Go into Sound Manager and make sure it's set to HDMI Bitstream. Also go into the SPMC settings > System > System > Audio and enable Passthrough if you want it turned on.
            Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
              I tried that, using both default & HDMI Bitstream, restarted ect. I don't even have any sound clicks/Touch sounds, MXplayer , nothing no sound at all. I tried SPMC and Wasser-Kodi, just reverted back to V2.0.3 and I have sound again.
              Also having problem with SPMC loosing sync with audio when I start a new video it goes to scratchy noise, I click on volume disable/ re-enable Passthrough and I get it back, but it's kind of annoying.
                That's odd. I'll try my 4, R28's next week when and see.
                  Tronsmart Orion R28 meta + Wasser 2.0.4a and audio is working fine here via hdmi bitstream. 2ch setup here. Over hdmi from orion to tv and over optical from tv to old yamaha receiver (dsp-e800).
                    Yup. Same here.
                      NEW - Wasser Firmware V2.0.4 for Beelink R89
                      No sound as well on my firefly
                      Sent from my LG-D802 using Forum Fiend v1.2.14.
                        Both stock and wasser rom has a history of audio issues on some setups. Is it due to RK sdk or what is the issue?
                        Beelink R89
                        Pioneer SC-2022
                        Samsung 55" LED 2012
                        Previous:
                        Minix X8-H
                        Minix X5
                        Logitech Revue
                          No sound over SPDIF
                          With Wasser 2.0.4a on Tronsmart R28 Meta I have no sound over SPDIF-Out. Has anybody an idea what I can do to solve the problem?
                            You guys are right. The Wasser 2.0.4a rom doesn't have audio over HMDI. Good thing 2.0.3 works.
                              admin please delete
                                Amazon Instant Video
                                @Wasser
                                If possible, please add Amazon Instant Video app back to firmware.
                                Tronsmart Orion R28 Meta. Wasser Lollipop Beta 5 (very stable). Video Out: 60" 1080p LG Plasma TV-HDMI 1.3. Audio Out: Default (stable). Remote In: TaoTronics TT-MK005 Air keyboard/mouse (keys repeating). Apps: Kodi (stable), Plex (stable), WatchESPN (Stable), Amazon (Stable).
