Kikat - Wasser Firmware for Beelink R89
Originally posted by bluesmanuk View PostWith regards to disabling RKlibstagefright in SPMC 14.1.0_beta1 to remove stutters, I take it that this will mean that everything will revert back to software instead of hardware decoding?
Originally posted by BTR11 View PostBut Wasser had said to run with hardware decoding libstagefright & mediacodec both "On", just disable Rklibstagefright; I´m just wodering if this is the situation can latest Kodi 15 nightly build work Ok with both libstagefright and mediacodec "on", because there is not rkstagefright on it?R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
If I flash 2.0.4a, do I still need to apply the update-kernel-fix-2.0.4.zip patch as well?R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by gismo112 View PostWasser, thanks for your nice Job.
Sry, the Problem is not fix for me in 2.0.4a. No Sound over HDMI
Can this come with the CEC-Support and is the HDMI-CEC-Support in Kernel or in System ?
Greets Gismo( also set the hdmi bitstream setting within the android audio settings.and did a restart)
Within the 2.0.3 firmware the sound over HDMI was working great.
I guess i'll have to flash 2.0.3 again.
regards
Originally posted by wasser View PostThere 2 diffrent things. what nagra did is that they raised the sdio freq which can cause Problem with 5g Routers.
I die not do that, but only did update the driver
And rename system/etc/firmware/config_US.txt /system/etc/firmware/config_US.txt to config.txt
Then your 5 ghz router will be deteced fine
Ps this is ment for the rom makers out hereMy players,
Ac Ryan Veolo 2
Ac Ryan Veolo 4K
Ac Ryan Playon!HD2
Ac Ryan Playon!HD3
After a thorough test of 2.0.4a I have zero micro stutters in SPMC (with rklibstagefright enabled) with almost all media and have noticed that one of the 4k videos that normally shows very visible stutter towards the back end of the video has a cleaner, if not perfect playback.
So another improvement overall for me.
R: NEW - Wasser Firmware V2.0.4 for Beelink R89/Tronsmart R28
i've update wasser 2.0.4a + Spmc 14.1.0 beta1 on my Ubox 2/8gb.
i've the same problem like first firmware stock and all other firmware i've tried.
i've micro jerky every 3-5min when I play video. for example on "despicable me" i've a lot of micro jerky. i' ve tried mx player, stock player, km player....
Someone has solved the problem? what can I do?
please help me.... i'm desperate?
MXIII with Amlogic s802 works better then ubox...
Originally posted by crazymark View Posti've update wasser 2.0.4a + Spmc 14.1.0 beta1 on my Ubox 2/8gb.
Originally posted by d4nny82 View Postfor me videos up to 1080p are playing perfect without drop or skip using 2.0.4a
thanks a lot for your help.
is possible depend for bad setting of the HDMI output?
is possible depend for TV Model?Last edited by crazymark; 20 January 2015, 10:01.
There are currently 3091 users online. 2 members and 3089 guests.
