Kikat - Wasser Firmware for Beelink R89
Originally posted by wasser View Post
360 controller is supported in my firmware, it's compiled in the kernel. You dont need the kernel modules for that.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
Originally posted by Henkdevries View Post
Try "Volume Lock & Control".
Works for me.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
I have an app (PBS Kids) that won't recognize the landscape mode correctly for this image. Is there anything I can do or set in build prop to try to fix this? I've dug through a lot of build prop settings and none have worked.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by amclean123 View PostI have an app (PBS Kids) that won't recognize the landscape mode correctly for this image. Is there anything I can do or set in build prop to try to fix this? I've dug through a lot of build prop settings and none have worked.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Wasser
There's a setting for rotation in settings->display, you can set it to landscape position and it will be locked for this. This feature is only available in 2.0.8 or later
WasserTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Over the past three weeks and after doing much more testing on 2.0.7, 2.0.8, 2.0.9a "Volume Lock & Control" has fixed my muting issues on SPDIF and HDMI passthrough out on my Panasonic TVs, Yamaha AV receivers, and Pioneer Receiver. This has even passed the kids and wife test. Things always break for them when I leave the house. I tried other Volume lock apps and they didn't work. Wasser I wouldn't spend anymore time trying to fix it. Maybe install the "Volume Lock & Control" app by default. SPMC 14.2 is running flawlessly over wired LAN. Very good ROM! I'd say you've made the perfect ROM for video playing.Last edited by amclean123; 19 June 2015, 18:51.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
I am using version 2.09a since you post it with no issues but suddenly AC3 and DTS stopped working in PLEX
I don't know what happent, one day it worked fine and the next day it didn't. I re flashed 2.09a but problem still there.
I thought that the problem might be by a newer version of PLEX so I flashed 2.08 to see if I will get the problem there too (I didn't have such problem with 2.08 when I was using it in the past). No problem in version 2.08, it works fine.
wasser
tell me , version 2.0.9a will still be updated? Or you finally preshlos to version 3.0.0 beta1. (NEW - Lollipop - Wasser Firmware for Beelink R89)The cooling system on Tronsmart Orion R28 Meta Wasser2.0.9a)
Originally posted by dragon92 View PostHow do increased memory in, while it only 2gb help
If you mean RAM it is soldered to the board and without skilled electronic technican you can't upgrade it's capacity.
Originally posted by aundp View PostHi people!!!
On 2.0.9a sometimes, out of the blue, sound may disappear and wont come back only after restart.
Does anyone have same issue and/or solution to it, besides going back to 2.0.8?
It is known "mute bug". I can not recall in which versions of Wasser's firmware it is happening. Newest Lolipop also isn't free from those occurences.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
There are currently 1942 users online. 1 members and 1941 guests.
