Very strange...
Kikat - Wasser Firmware for Beelink R89
Originally posted by wasser View Post
i'm not sure why this rom has perfect playback. I played around with this firmware and found a lot of issues in playback.
for Example:- AC3 format can not be played
- video stutter
- google play movie doesn't work
- google play music silent issue
- and more ....
What i really like to hear and comments what is better in this firmware and what work in this fw and not work in my firmware. Such feedbacks are important for me to improve the FW. Does the The random audio mute issue appear in this rom?
It doesn't help me if just only tell me it has perfect playback!
I really want to fix the random audio mute issue, but somehow i really cannot reproduce this issue. Without a reproduceable testcase it's not possible to debug and fix it!
So please try to find a reproduceable testcase so i can reproduce it!
I'm not against your firmware and will not criticize the contrary say thank you for the work.
Watered implausible to criticism that is not my principle.
Thanks again!
Originally posted by ErnestoGuevara7 View PostI noticed a couple of glitches in Wasser Firmware version 2.0.9a
- Last night just missing the sound of the entire console. ( rebooted , everything came back to normal. That was until only 1 time )
- MX player when watching IPTV HD channels appeared discrepancy pictures with sound for 1 sec ( rebooted , everything came back to normal. That was until only 1 time )
install now beelink-r89-sound-fix.zip
Tronsmart Orion R28 Meta (Wasser2.0.9a)/MicroSD 32GB/iPega PG-9021
MX 1.7.37+v7 neon 1.7.37
Wasser Firmware V2.0.9а ubdate cpu1920 ddr 700 gpu625
Tronsmart Orion R28 Pro
Originally posted by hisound View PostBefore you criticize someone else's firmware, get your own.
Thanks again!
I don't get what you are moaning about.
Wasser was simply giving his feedback on another ROM and what issues he found.
ROM's are supposed to be open source, so it's not a case of anybody getting their own ROM, so your first comment makes no sense whatsoever.
ROM's are supposed to be open source, so it's not a case of anybody getting their own ROM, so your first comment makes no sense whatsoever.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
There is a positive but not moan.
All these issues are fixed in 1.0.4
Originally posted by hisound View PostAll these issues are fixed in 1.0.4
But for me Wasser's firmware has two major advantages:
1. Unified userdata memory with emulated SD card on ext4 file system (apps + downloaded files of size grater than 4GiB).
2. Mouse movement doesn't wakeup device from sleep.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Different question. Can anyone connect your device to PC and see files on internal memory? I think in OHC moded firmware and first Wasser's KR2388 ROMs it worked but now I do not get any prompt on Windows 8.1 64bit.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostDifferent question. Can anyone connect your device to PC and see files on internal memory? I think in OHC moded firmware and first Wasser's KR2388 ROMs it worked but now I do not get any prompt on Windows 8.1 64bit.
I assume that xpad.ko (360 controller support) is out the question currently?Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
Originally posted by uli-hh View PostI use MyPhoneExplorer for this and more on all my devices.
Originally posted by ididmytime View PostI assume that xpad.ko (360 controller support) is out the question currently?RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostI haven't seen kernel source code but it might not include that module.
Tried on my CX919 with Wasser and D3's kernel and 360 controllers work flawlessly, on this rom everything works but the D-Pad unless in a very select few apps like Moonlight.
Sorely tempted to sell it and get an Amlogic. I'll miss the power but you can't beat the open nature.
Currently Using:
Retired Devices:
There are currently 2729 users online. 0 members and 2729 guests.
