I am afraid that it will never solve.?
Kikat - Wasser Firmware for Beelink R89
Originally posted by wasser View PostHi all,
i uploaded beelink-r89-sound-fix.zip. User who has sound issue please update it and report the results to me!
WasserTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by torbvea View PostI have tested the sound fix for some time now and sadly I still get audio dropouts with HDMI Passthrough in SPMC, Spotify, Youtube.. I also got a random audio mute one time. I have sent you a new log file as a private message Wasser. Thank you!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I used an older rom (I think it was 2.0.5) via boot from SD-Card without any problems at a UGOOS UT3S (which is the same pcb like HPH without HDMI-IN and with HDMI 2.0) but I didn't tested the IR (which I bet will not work)...
RK3288 Devices
- Overview BOX (LINK !)
When you say audio dropout, do you mean a blip or hickup every 3 seconds?
Originally posted by slyger View Postdoes anyone know offhand if the latest OC kernel is stable on a Ubox R89?
Important notice:
One should be aware that OC update for Wasser's 2.0.9a firmware changes kernel and resource file placement. After applying this update you will have to search in MTD boot partition for current OC settings. That will matter if someone want to undo OC (flash oryginal boot.img which is smaller than 2MiB) or change it with help of overclockmatic_RK3288 tool (option number 1).RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Hello Wasser, I sent you a pm with my dropbox link for my log files showing the audio errors. I get an audio hickup every 3 seconds while playing a video from the latest Kodi 15 nightly, both Dolby and DTS. I am connected by HDMI from my Beelink R89 to my new Denon AV receiver. I am playing the videos from my Synology NAS, When I try to play the same files from my NAS using ESFile explorer, and MX player it says AC3 format not supported. My other external audio apps will not play them either, I have never run into this problem.
i checked the log files, it looks like a bug in kod 15i which causes audio hickup. Could you also please try spmc-14.2 ?
Wasser
I flashed this fix. But my problem continiue.
My device video: https://docs.google.com/file/d/0B4Bp...XRvd1NNQVJtZ1E
Tronsmart Orion R28 Meta RK3288 Wasser 2.0.3
Samsung Galaxy S4 GT-I9500 4.4.2 OzcanRom.v6.3
wasser ... about random sound mute.
Here you can fin logs (take with syslog) . I take it few seconds after random mute.
Hope it can help
R28 2.09a firmware - OC kernel - default hdmi sound.
Hi Wasser ,
After using the new 2.0.9a rom , i have a problem with the display resolution in HDMI (1080p/60hz),
the box display area is over my tv screen and cause something hidden or show incomplete ,
my box is beelink u89 , what can i do to solve this problem , thanks.
mxplayer should play AC3 forma wihout any problem, it looks llke you did not flash the latest 2.0.9a. Please download it flash again. Plese report results if this issue does appear in mxplayer
From my few test, this is by far the best firmware for my Beelink R89 8gig version. Excellent job. beers to come, thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1966 users online. 0 members and 1966 guests.
