Kikat - Wasser Firmware for Beelink R89
    Originally posted by wasser View Post
    Please don't use this on firmware 2.0.8. It's not compatible!
    Can you post the factory kernel for Wasser 2.0.8 please? Many thanks!
      You can find it at the 2.0.8 img... you have to unpack the all-in-one image with AndroidToolv2.3 at the tab [Advanced Functions] at "Firmware"...
      First you have to select the all-in-one image with [...] and then press [Unpack]
      Then you will find at the sub-folder/directory "Output\Android\Image" the files...
      RK3288 Devices
      - Overview BOX (LINK !)
        Hi all,
        Wasser Firmware 2.0.9 for Beelink R89 is released. For more infos please take a look at the first post!
        Please report the feedbacks, it's very important for me to improve the firmware!
        Enjoy!
        Wasser
          Installed 2.0.9 on my R28 Meta and the first thing that I noticed was that whilst I was able to see both 2.4 and 5Ghz wireless networks, I was only able to connect on 2.4.
          Update: It's now decided to connect although nothing has changed.
            Great Thanks for Firmware!!!!
            How i can update the FW from older version (without data loss)?
            THX
              THX
              You can't.
              You will have to backup data/apps first.
                i really want to fix this issue, but noone can give me a reproduce for this issue !
                Wasser
                The only thing I "do" to get the dropouts is to set audio output to HDMI Bitstream in the android settings. The TV Box is connected to my AV Receiver. Then I can play a movie/music with any app and I get random audio dropouts. Do you have your box connected to an AV Receiver wasser? I can understand that you can't reproduce the dropouts if you have the the box connected directly to the TV, then there is no problem with dropouts.
                Appreciate all your effort! Thanks for the new v2.0.9, will try it later today!
                  If wasser isn't able to reproduce the issue, maybe it would be helpful to support him with log files http://freaktab.com/forum/tv-player-...-get-a-logfile
                  RK3288 Devices
                    I will try to provide some log files.
                      Hi Wasser,
                      Thanks for your effort!!!
                      Can you also update the overclocked kernels?
                        Hi Wasser
                        Again, thanks for your continued work - much appreciated.
                        My set-up is straightforward - R28 connected to TV by HDMI and to internet by ethernet. I get sound with 2.0.7 on my old TV but no sound with 2.0.8 or 2.0.9. However I do get sound on my newer TV with 2.0.7. 2.0.8 and 2.0.9.
                        I had the muting issue with 2.0.7 (both TVs) but not with 2.0.8. This would be consistent with the possible EDID explanation put forward by LawlessPPC (#1234) and amclean123 (#1238 and #1239).
                          Originally posted by ManxYessir View Post
                          Hi Wasser
                          i need log files (kernel log files and catlog file), one with working sound on new tv an one with sound issue on old TV. both please with 2.0.9 FW.
                            Hi all,
                            i uploaded the new kernel which should fix "no sound with some TV" issue, only people who has this issue, please test it and let me know if it works.
                            http://www.freak-tab.de/wasser/kerne...-hdmisound.img
                              Hi all,
                              Enjoy!
                              Wasser
                              Thanks Wasser. I'll download, flash and see how things look. I'll test the new SPMC beta 1 too. It was giving me problems over HDMI that SPMC 14.2 didn't have.
                              Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
                                Thank you Wasser for your great job.
                                Report issue for a couple times .
                                Camera app it does not work properly .
                                Crashes when I start video recording.
                                I have c270 logitech cam.
                                Thanks.
