Kikat - Wasser Firmware for Beelink R89
Originally posted by gffmac View PostMicro stutter is fixed with this rom, works great on my Tronsmart Orion. Thanks for the heads up! Launcher is interesting too.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
For those of you that are having trouble flashing your R28 I made a video on how to flash the R28 by shorting pins on the PCB https://www.youtube.com/watch?v=K9lLJirKEIQ. You can use this method to flash back to the original firmware, Wasser, or Open Hour. Hope it helps.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by Chasem View PostIs the stuttering fixed in SPMC though?
I can't see any stutters with kodi... a lot with SPMC...
I check with many h264, xvid codecs. 1080P/720P files.
Strange... i know
Originally posted by roolmapool View PostKodi (v14 stable release) is much better than SPMC 13,4 or 14Beta2 with my device (R28 v2 + wasser 2.03).
Strange... i know
Other factors of setup and configuration may of course result in differing experiences.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by amclean123 View PostFor those of you that are having trouble flashing your R28 I made a video on how to flash the R28 by shorting pins on the PCB https://www.youtube.com/watch?v=K9lLJirKEIQ. You can use this method to flash back to the original firmware, Wasser, or Open Hour. Hope it helps.
ThanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Thanks in advance.
Originally posted by Tarwin View PostHi. I am thinking of trying this ROM. Can you install it normally or does something need to be done so that it can be installed on the R89?
Thanks in advance.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
So, people can check last stable Kodi... Both app can be installed
Originally posted by Henkdevries View Post
does the r28 stock remote work with this firmware?
So had to go back to stock rom for R28.
The only way to get it working with any rom, as per BOB is to, use stock Kernel and Stock resource files.
And untill now I have not been able to extract/find Stock Kernel. Did with extracting boot.ing and all but no luck.
Would really appreciate if anyone here has extracted KERNEL and RESOURSE successfully and would please upload it.
thanks
There are currently 2778 users online. 0 members and 2778 guests.
