Kikat - Wasser Firmware for Beelink R89
NEW - Wasser Firmware V2.0.4 for Beelink R89/Tronsmart R28
Originally posted by theeze View Postno wifi issues with orion meta. Pro uses a different wifi module,I don't know what beelink r98 uses but if it's the same chip as the meta, I can see why it wouldn't work on the pro. Although it might be completely unrelated.
Does it at least scan the network? What happens if you try to turn wifi on through the settings on android? Error message? Crash?
new kernel update fixes wifi/sdcard issue
Hi all,
i uploaded new update-kernel-fix-2.0.5-1.zip which should fix wifi/sdcard issue. Please test and give me feedbacks!
Download: http://www.freak-tab.de/wasser/updat...ix-2.0.5-1.zip
Wasser
Wasser
Originally posted by mghb View PostStill I have problem with wifi display after update 2.0.5-1.zip.
1 what is your device?
2 does this issue happen in all earlier version? if not, in which version did wifi work for you?
The problem is that i cannot reproduce these issue on my R89 PCB V2.0. All work fine for me!
Tanks
Wasser
Wasser
Originally posted by d4nny82 View Poststill can not turn on wifi even after update (orion r28 pro)
the Beelink R89 which i have has ap6335!
It's expected that wifi won't work for you if your device doesn't have ap6335. I'm just confused that some users said wifi works in my earlier fw version!
Wasser
Originally posted by DiZet View PostFor me the Wifi works fine on earlier version V2.0.4a
It's really strange! the kernel which included in 2.0.5-1.zip is the same which is used in 2.0.4a
Wasser
i use most for movie like popcorn time. with 2.0.2 the play it was not good , with 2.0.5 is very smooth and like in normal pc , but have little freeze for 1 or 2 sec , or sound go off during play . the mute of the sound is something that happened , but i have a remote and OK.
WASSER thank u for good work.
Originally posted by wasser View Postwhich device is it? does your device has ap6330?
Wasser
Tanks
Wasser
thanks.
Originally posted by mghb View PostI have r89 pcb v2 and don't have problem with the last original firmware r89 but with all your firmware I have problem with wifi display.my tablet is p601.
thanks.
Originally posted by DiZet View PostIt is the same as above orion r28 pro. I think R28 Pro version has a different chip ap6210. It is strange because I have one box that is running now on 2.0.4a firmware with wifi on and other one with 2.0.5 and 2.0.5-1 kernel fix and no wifi. In about device in kernel version it is now: 3.10.0 [email protected]#1 Tue Jan27 22:40:09 CET 2015. On 2.0.4a is the same except the date Sun Jan18 12:33:57CET2015
3.10.0
[email protected]#1
Thu Feb 5 19:31:46 CET 2015
You have tested old kernel!!! not the new one in 2.0.5-1
please check your update again?
There are currently 2730 users online. 0 members and 2730 guests.
