NEW - Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.1 ROM
Originally posted by Trex View PostIt's not work for me. I even did boot SD card, but it also stuck in same place...
Originally posted by lost2 View Postdid you try to format first the sd card ? some times helps (something like sd card bug), try to re download the rom if not , try to flash the stock rom with the same method else you have to try with usb burning tool
I think firmware not compatible with MXIII 1/8Gb... No problem with stock.
update
OK just an update, i flashed stock recovery back onto the box. booted into stock recovery, Wiped everything and installed stock 112 from oman forum . Install went OK and box is alive againFor some reason it will not accpet bobs rom i dont understand it... I was afraid my box was dead but its working now. Maybe something not compatible with finless rom on the 1g/8g ?
Originally posted by londonshore View Posthey bob will you release a 2.2 since 112k4 is out ?
if so can u add tsn go fix to it pleasethanks
Originally posted by willyghost View PostHi Finless,
Do you have any idea why i cant get your rom on my box ? Like i wrote before the stock 112 installed OK, when i try your rom it starts to install it just freezes, i have the MXIII 1g/8g...
Yes, the only way i was able to revive my box from recovery boot loop was the following:
Downloaded your rom
Extracted the stock recovery zip file and flashed it
Downloaded stock 112 from oman forum and copied just the 112 rom zip to my SD card
Entered stock recovery with toothpick method
Did full wipe on stock recovery
Chose instal zip from EXT and Flashed the stock rom 112 from my sd card
Install took about 3 minutes
completed and rebooted
all ok
Download link fixed by request.
Originally posted by Finless View PostI honestly have no idea other than bad, old, slow SDcards may not work! Are you able to flash any ROM? like stock?
Originally posted by gsaylor27 View PostFinless,
I cleared my dalvik and cache from TWRP and fixed premissions and now I have lost root. My device says it's rooted still under CPUZ but SuperSu is saying device isn't rooted. How can I fix this without reinstalling everything?
There are currently 4230 users online. 0 members and 4230 guests.
