NEW - Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.1 ROM
Originally posted by visuvius View Post
Google Movies and other online DRM video services
Hello Bob,
thank you a lot for your ROM- I use this on MXIII/2G. Seems very stable and fast (Antutu 5.5 - 38415 points), also highly APP compatible. But I have no luck with Google Movies and other online DRM video services I tested - I have only audio, but no video. Please, is that possible to solve this bug?
Thank you and Happy New Year
Tomas
P.S.: I am going to buy a beer for you
It seems there is an "Android 4.2" problem with empty mounted cifs directories.
There is a topic regarding the issue at xda.
Or is it just me? Can anyone test mounting cifs share (NAS or so) to local mount.
I have Win2k8R2 cifs share, latest Finless 2.1, Tronsmart S89. And i have tried both CifsManager and Mount Manager.
Thank you for your time! =)
upd. accessing cifs using kodi (xbmc) is ok, everything fine. it's only a local mount problem.
Originally posted by Magnus33 View PostYou need the sixaxis app to connect controllers but yes to both.
https://play.google.com/store/apps/d...ntroller&hl=en
Same for me .
Originally posted by masseselsev View PostIt seems there is an "Android 4.2" problem with empty mounted cifs directories.
Exactly the same for me . I can mount my Nas (Synology Disk station in Kodi. Have tried several apps in the os itself with no go.. I Can access with the Synology File app and FTP With fx explorer ..
Originally posted by pythonas View PostThat is an exellent job from bob and many thanks to him!!! i am not sure if this is true but i tested my vega s82-h with antutu and i have score of 39992 !!!!!!! my question to you bob if that is true?
Hey guys the ones using oman 13.4 xbmc based on SPMC. Are you usig amlcodec? i still get drops and skips with AMLcodec but if i use libstagefrigh and mediacodec i get audio and video sync issues. I'm loading videos using nfs and my server box is right next to it, all ethernet wired. Before i had my 3tb hdd plugged in to the vega box with no problems but now i do.
what are your thoughts, setup using a media server / NAS?
mediabox settings wizard loop
ROM appears to be working great for me except every boot up it pops up with the mediabox settings wizard, anyone came across this before? I used flash method #2 in the readme
Its remembering the apps and other settings once i skip through it but seems to think its a fresh install each boot?
Originally posted by ASW1 View PostQuestion:
in the READmEFIRST.TXT it says: "TWRP recovery is intsalled with this ROM"
However when I boot into recovery it doesn't look like TWRP, more like CMW.
Also I don't see the option to make a full back-up.
Do I still need to manually install TWRP, and if so, how do I do that?
READ THE README!
Originally posted by Finless View PostIf you leave a recovery on SDcard then it's going to boot into that!
Originally posted by Finless View PostREAD THE README!
I see now that there is another readmefirst.txt in the flash_recovery folder, but I never looked in there assuming I wouldn't need those files (and this turns out to be correct, I don't need to go there)
Well, thanks a lot anyway.
There are currently 3284 users online. 1 members and 3283 guests.
