Sunchip CX-W8 (Z3735F)
Hello, I need this BIOS. give a link please.
BIos SMB1. DW8RNNN01
restored the BIOShttps://yadi.sk/d/j8IirC2Mnd3NH
I upgraded CX-W8 from Win 8.1 to Win 10 with an image file sent by the reseller (https://drive.google.com/open?id=0B8...C1VZGJSRWc1MlE) The problem is that the Android/Windows boot menu is now screwed. When I click on Windows I get a BSOD: Recovery Your PC needs to be repaired. Error code: 0x0000034 and it sends me to the BIOS. The only way to boot into Windows is to choose Override Bootmenu from the BIOS. Is there any way to fix the boot menu?
My Wintel CX-W8 doesn't want to boot anymore, and I cannot see any display.
All the time, I had problems with the "integrated device", really annoying with my lcd tv, and this cx-W8 never wanted to start without any tv or monitor...
I decided to enter bios, and disabled "Integrated Graphics Device", but I am totally blind now, cause I can't see the bios anymore, none display :-(
Could someone help me to enter bios and reset bios to defaults, with down right right to enter SCU, right to go to advanced tab, down enter to enable integrated or something, or simply the "bios defaults" with F3, but with up or down or "y" to valid? and F4 or F10 to save and exit, with or without "y" ?
Thanks a lot ;-)
Hi !
I just received my Wintel and test it.
After that I found a problem on Android mode that no audio out but on Windows 10 mode everything include Audio is ok.
I used Smart TV Samsung Model UA46F7100.
If I switch from Android 4.4.4 to Windows 10. Play movie or music . Video and Audio via HDMI on the same Smart TV work fine.
The other point was if I used HDMI to VGA converter and plug in speaker via Converter audio output was OK.
My wintel Box firmware detail:
- Model no. w8
- Android Version 4.4.4
- IFWI version 5.6.5
- Kernel Version 3.10.20
arron@developer-server#1
Mon Aug 10 11:42:05 CST 2015
Build no.
KTU84P.eng.arron.20150831.114105 dev-keys
After investigate for a few days, and test my smart TV with myfriend's Wintel CX-W8. It's work in Android mode with audio output. I found that his box use new android software .
My friend's wintel Box firmware detail:
- Model no. cx-w8
- IFWI version SMB1.DW8RNNN01
root@cxr-server#1
Mon Dec 710:26:29 CST 2015
Build no.
CX-W8 20151207:182324
Please review and adv.
and New Build no - Download?
I expect Android software that handle HDMI & Audio may be the cause of this problem.
Thanks in advance.
Originally posted by scjack View PostHi !
I just received my Wintel W8 and test it.
.....I found a problem on Android mode that no audio out but on Windows 10 mode everything include Audio is ok.....
There are currently 2383 users online. 4 members and 2379 guests.
