I have tested this on my W8 and it works perfect.
Sunchip CX-W8 (Z3735F)
i flashed mine aswell and it works like a charm. Much more bios settings, just like cx-w8.
Although when i flashed the bios, windows found aditional devices. 3 axis sensor was no problem to get drive for.
But when i enabled the otg usb, i get this device with no drivers...
Anyone has any ideas where to get drivers for this ?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
So, i've updated the driver package to include the sensor drivers and the new BIOS.
3-axis sensor driver no longer causes cpu load. Using HP's driver solved that.
Download here https://mega.co.nz/#!ppcHwBDB!JEHRlG...TUB-dhWuX90CSk
Originally posted by hojnikb View Posti flashed mine aswell and it works like a charm. Much more bios settings, just like cx-w8.
Anyone has any ideas where to get drivers for this ?Originally posted by hojnikb View PostSo, i've updated the driver package to include the sensor drivers and the new BIOS.
I didn't get any problem
I have the dual boot Wintel w8 box and i've somehow messed around with the drive partitions to the point where it will now boot into the BIOS but wont recognise any Windows installation USB drive. Is there any chance i'll be able to bring this box back to life, or have i basically bricked it (because i cant boot Windows, Android, or get it to see any installation media).
Is there any way i might be able to use to OTC usb port to revive it?
Thanks for any help
Originally posted by emmathon1 View PostI have the dual boot Wintel w8 box and i've somehow messed around with the drive partitions to the point where it will now boot into the BIOS but wont recognise any Windows installation USB drive. Is there any chance i'll be able to bring this box back to life, or have i basically bricked it (because i cant boot Windows, Android, or get it to see any installation media).
Thanks for any help
[QUOTE=emmathon1;n513209]I have the dual boot Wintel w8 box and i've somehow messed around with the drive partitions to the point where it will now boot into the BIOS but wont recognise any Windows installation USB drive. Is there any chance i'll be able to bring this box back to life, or have i basically bricked it (because i cant boot Windows, Android, or get it to see any installation media).
R u able to boot into Android or not?
Originally posted by emmathon1 View PostI can't get it to boot to android or windows or see a windows installation usb. I can literally only get to BIOS screen. I made the usb installation with the settings in the first post with Rufus and Windows 8.1 generated with the Microsoft official tool.
Thank you for helping
No need to make usb with rufus if you are using microsoft official tool. Try this- Repeatedly press F7 when you switch on your box and then select UEFI:USB from there. It should start windows installation.
If not then try another method-
If you are still not getting installation for any reason and your box is keep booting in android then here is one more solution.
There is one reset button behind audio jack of your TV box.
Shut down your box
You need to press that reset button (with help of tooth pick or any similar thing) along with power button and keep pressing reset button until you see dual boot screen (same as above picture)
Select Windows icon and hit enter. Hopefully you are now installing windows
instructions are here http://freaktab.com/forum/tv-player-support/intel-based-tv-players/511168-solved-install-upgrade-android-in-dual-boot-intel-box-stuck-at-uefi-built-in-efi-shell-while-booting-for-pipo-x7s-w8-etc
Originally posted by Methanoid View PostReplaced my original post with links to helpful info.. PM me suggestions for more!!
Home Page of Manufacturer http://www.sunchip-tech.com/prod_vie...FId=t3:50001:3
Pics of PCB http://freaktab.com/forum/tv-player-...753#post405753
Alternative Clones/Rebadges http://freaktab.com/forum/tv-player-...548#post406548
Enter BIOS with ESC - do NOT mess with it http://freaktab.com/forum/tv-player-...492#post492492
BIOS (how to reflash?). Drivers http://freaktab.com/forum/tv-player-...116#post412116
Drivers again http://freaktab.com/forum/tv-player-...075#post413075
Re-install Windows? Use Rufus for USB stick but Must select MBR Partition Scheme for UEFI (only!) and FAT for your USB build
Auto Power on http://freaktab.com/forum/tv-player-...650#post419650
Ghetto cooling mods http://freaktab.com/forum/tv-player-...464#post427464
I have a tv box is just a reach windows
How do I add Android? You know I can not explain
See my problem here:
There are currently 1622 users online. 3 members and 1619 guests.
