Sunchip CX-W8 (Z3735F)
Originally posted by hjpca View Post
need help any thanks
This link helped me when I reflashed my BIOS: https://plus.google.com/+IanMORRISON/posts/5EuA7nFU9JA
It is for a different board (intel stick) but the procedure is basically the same, look for the flash chip as it varies depending on the version of board you have and make sure you line up the correct pin numbers.
There are many different BIOS files around so make sure you take a copy of your current one before reflashing (even if it doesn't work, if everything goes bad then later on you can compare your original to others online).
Here is a link to a BIOS file that may work: http://freaktab.com/forum/tv-player-...-z3735f/page14
Originally posted by kiccome View PostGood morning. I just bought a computer Wintel W8 with installed Win10 and Android 4.4. I wonder if anyone has tried to replace Win 10 with Win7 and with what results.
Thank you so much.
Originally posted by TroisSix View PostHi,
My Wintel CX-W8 doesn't want to boot anymore, and I cannot see any display.
All the time, I had problems with the "integrated device", really annoying with my lcd tv, and this cx-W8 never wanted to start without any tv or monitor...
I decided to enter bios, and disabled "Integrated Graphics Device", but I am totally blind now, cause I can't see the bios anymore, none display :-(
Could someone help me to enter bios and reset bios to defaults, with down right right to enter SCU, right to go to advanced tab, down enter to enable integrated or something, or simply the "bios defaults" with F3, but with up or down or "y" to valid? and F4 or F10 to save and exit, with or without "y" ?
Thanks a lot ;-)
There are currently 1961 users online. 1 members and 1960 guests.
