Solution: load in appstore a tool down, named soundabout.....after install it, go in setting, mark HDMI sound, NOT automatic...and sound is there!
Sunchip CX-W8 (Z3735F)
Hello, someone can help me ?
i've got a problem with an WINTEL DUAL BOOT W10/ANDROID box : now i can't boot on android (only windows boot is ok) : when i boot, i've got the screen with the choice, when i select android, the BOX enter in bios setup.
when i buy this box the dual boot was ok and after i've tried to modified some setting...after i've tried several times to load "optimized setting" but nothing change...
Can you help me ??
some screenshots :
Hello all,
I just bought a wintel pro cx-w8 on which I want to install only kubuntu 16.04LTS.
I choosed it for the price and the comments on the ability of the device to run linux.
I don't know how to do all the process to get kubuntu running on this device.
What are the steps and how to proceed.
Need a help.
Thanks by advance.
looking for info..i just got a EZP XPRO programmer need info how to use it .and bios bin file for the wintel w8 box..any help would be very awesome..thankyou all
I got ezp xpro software running on windows 10 and I got the clips for the bios chip..just looking for some help..if anyone have done this before
Originally posted by hjpca View Postlooking for info..i just got a EZP XPRO programmer need info how to use it .and bios bin file for the wintel w8 box..any help would be very awesome..thankyou all
Hi there, I've only just bought a Wintel W8 Windows 10 TV Box, it was working fine yesterday, but when I've went to switch it on today, it is sitting on a red light which goes off after a bit of time. If I hold in the power button, then the red light goes to blue for a short time then it switches off. No matter what I do I can't get the solid blue light on. Just wondering if anyone has an experience of this issue and if it can be fixed.
I have a Wintel W8 that does boot (blue LED does not light up). This happened after I replaced and flashed the BIOS chip (a Winbond W25Q64FWSIG) with another. Previously the blue LED would light up but there would be no display out of the HDMI port.
Has anyone had this happen before? Is there anyway I can debug what part of the boot process it is getting stuck at electronically?
The board version is: W8 V2_3 20150509
There are currently 2295 users online. 3 members and 2292 guests.
