So I cant just boot from usb stick and do regular w10 install? Do I need to backup activation or it will activate on its own from bios like pipo did? Thanks again!
Sunchip CX-W8 (Z3735F)
So i did some more testing and tweaking today. Again hooking up a multimeter to the 5V supply (via usb).
I played around with the BIOS settings and with the new bios (which offers a lot of settings) i set the SoC passive trip to 65C. This yields in faster throttling of the SoC itself. Which may not be desired by some, but it has some nice side effects. Since throttling occurs very soon (given the low limit) it limits the power SoC draws. This turns out to be beneficial as it appears that dc-dc voltage regulation is poor on this board.
So if anyone is experiencing similar shutdowns, i recommend flashing the latest bios and setting SoC passive trip to 65C. This way its very unlikely that 5V rail will dip below critical level (and thus board shut itself down).
I'm planning on wiring everything that uses straight 5V directly from the DC jack (like usb ports, possibly lan and wireless). This would put less load on the voltage regulation itself. Its not the best practice, but its the easiest way to get around this issue.
Originally posted by Methanoid View PostReplaced my original post with links to helpful info.. PM me suggestions for more!!
Auto Power on http://freaktab.com/forum/tv-player-...650#post419650
The auto power on does not work; and I cant flash the bios I get a 280 error.
What I found out that makes the unit auto turn on is changing the OS to Android, but then the sound card and other devices on the unit stop working and appear with no drivers on the Devmgmt.msc
Recently, my Wintel box couldn't connect to Internet via WiFi or LAN. After checking, the LAN adapter was automatically set to a fixed IP address, even after I changed to "Automatically Obtain IP". Then I discovered "TAP Windows Adapter V9" was installed by default. Without knowing whether it's a spyware, I removed it.
The WiFi worked again by then. However, my LAN port has gone, i.e., it doesn't show up in the driver setting, nor the network adapter list anymore. I tried to installed the TAP drivers again but it didn't work.
The WiFi speed is not fast enough to stream some HD videos and making the LAN working again is important to me. Can anybody help?
Originally posted by monkey12 View PostTo help peoples with the realtek version
Here is the drivers that i have installed:
Baytrail drivers : https://mega.co.nz/#!l0wA0KpC!c7vMvR...-m4A-Z0wpXTpno
(do not use wifi and bluetooth inside, just BayTrail_Drivers folder)
Wifi driver : http://h10025.www1.hp.com/ewfrf/wc/s...em=ob-140101-1
Bluetooth driver : http://h10025.www1.hp.com/ewfrf/wc/s...em=ob-139344-1
I fooled around with my Wintel W8. Trying to delete Android and reinstalling windows with a full partition. I deleted all the partitions to create a large partition, but in doing so, the 29GB memory became 0 bytes. Appreciate if anyone can suggest how I can restore my memory partitions! Thanks. Peter
Originally posted by Petecheong View PostI fooled around with my Wintel W8. Trying to delete Android and reinstalling windows with a full partition. I deleted all the partitions to create a large partition, but in doing so, the 29GB memory became 0 bytes. Appreciate if anyone can suggest how I can restore my memory partitions! Thanks. Peter
Originally posted by TheLegendOfMart View PostIs there any way of installing Android on the version that came with just Windows?
There are currently 1971 users online. 1 members and 1970 guests.
