I have bought W8 dual boot but have accidentally deleted Android partition hence android is not booting up. I would be grateful if some body will help me on my these queries
1. Can I flash that with 64bit Bios as currently it is American Megatrend bios 32bit for windows and 64bit for android (I guess)?
2. Does any one have instructions on how to reinstall both windows and android as dual boot. Kind of fresh installation with instructions?
3. I tried couple of x86 android 4.4.2 to run and install from usb. it work somehow but doesn't support wifi, bluetooth, google play store so did anybody tried anything like this?
I Spoke with one of Chinese re seller today and they confirmed that W8 will be getting a new firmware update by end of this week. Once I get more information I will definitely share with you guys.
Methanoid - I tried to recover with mini tool but was unsuccessful. But I am trying some of other methods to be back on dual boot again.
dinosauria - I didn't try that as I know both are different Bios. My W8 says the current version of bios are W8_DOS_2.2B. (picture attached) do someone has copy of these bios?
dinosauria - I didn't try that as I know both are different Bios. My W8 says the current version of bios are W8_DOS_2.2B. (picture attached) do someone has copy of these bios?[ATTACH=CONFIG]n510588[/ATTACH]
Any word on the new bios ?
It would be also great if the new bios for W8 (dual boot one) would bring more settings, just like cx-w8 has.
How to reset bios ? Please tell me.
I also set HDMI wrong, nothing on the monitor but PC is alive.
I already update 64bit bios.
Hello. I am an begginer of CX-W8.
I also have same problems. Just I plugged off batt, but cmos is not cleaed.
I do not installed win 8 on my cx-w8.
Any ideas? for example, just like connect usb display or others.
and have questions of "How to boot ubunt form usb device"
(I think I can find this question if i search mor carefully)
Anyone has any ideas what that microUSB port is for ??
I tried powering up with a powersupply and using an otg cable. Nothing works..
Also, is anyone experiencing video skipping when watching youtube ? I get it while having hardware acceleration on, but when i turn it off, it plays perfectly fine.
I'm using opera 29
i can use the otg cable to connect the keyboard and mouse under win 8.1 pro x86
