Sunchip CX-W8 (Z3735F)
    Also, I don't own the device, but I read at the pipo x7 that they get a problem (brick) if they flash the dualboot to a single boot windows version, which seems to be because of a different bios version...
    So you should handle it with care!
    RK3288 Devices
    - Overview BOX (LINK !)
      Well I am probably gonna buy a 2nd box anyway... so I can rip the BIOS and the whole eMMC from that and see what happens maybe... unless someone else gets there first?
        Could anyone upload please the hp drivers, because i can't download it!
        Someone help!
          Replaced my 1st post with links to helpful info...
          FYI, pretty sure the new box is different hardware (IR works, PCB different chips) so cloning eMMC and BIOS may brick box. Not gonna try it now!
          http://freaktab.com/forum/tv-player-...735f#post23013 FIRST POST...
            Here's new version ?
            Last year, we were promised dual boot mini PC based on Intel that would run Windows 8.1 or Android 4.4, but finally companies decided against shipping a
              The new version looks like they removed the RX/TX pins on the board, also I see no IR sensor either.
                Other changes too and BIOS is now both UEFI 32/64bit... I think they are different factories... Not the same thing
                  This page has 64bit UEFI bios download link... Anyone tried this ?
                  Sunchip CX-W8 is an Intel Atom Z3735F TV box running Windows, but I've been informed that originally Sunchip designed it for WeTek in order to manufacture
                    Hi guys i need an help
                    I tried to make a dual boot with windows + ubuntu without success, then i completely formatted the hard disk to intall Ubuntu but i can not boot.
                    Now i want to reinstall windows 8.1 pro 32 with this procedure:
                    i'm using rufus 2.1.649 and i have a pendrive 8GB
                    the settings are: MBR for Uefi PC ( i've tryed also GPT for Uefi )
                    File system Fat32
                    Default Cluster (4096)
                    and i select win 8.1 32 iso image
                    The procedure go on without any problem.
                    I,ve also copied the file bootia32.efi in the pen under efi\boot (that i've downloaded from here when i've tried o install ubuntu )
                    Then i insert the pen and i enter in the bios pressing esc. I select "boot from file" and e select bootia32.efi but appera a black screen withthis message:
                    "gnu grub version 2.02 beta"
                    "grub>"
                    Am i using a wrong bootia32.efi? where can i download the right one ?
                    Am i making a few mistake ? which one ?
                      I don't know this boot from file at the BIOS, but at the MINX Z64 they found a way to use another w8wb and they have to use this way
                      NTFS because one of the files is bigger than 4GB and because of NTFS also the UEFI:NTFS...
                      Also [MBR partition scheme for BIOS or UEFI computers] instead of [GPT ....] is possible...
                      Maybe it helps you a little bit to setup the USB pen for/at w8pro....
                      (e.g. maybe you will find there a working efi at that image????)
                      RK3288 Devices
                        Hello friends, I wanted to know if you've tried the the emulator epsxe on our Sunchip CX -W8 ( Z3735F ) In my not work for me , it gives me error, black screen.
                          Hey
                          ​read this,
                          Is yours has android installed? I do not have, but really need.
                          Wintel W8 (aka Kingnovel K8) is an Intel Atom Z3735F mini PC inspired from Sunchip Wintel CX-W8 (the hardware is a little different), but instead of just
                            Hello, I have Wintel Box CX-W8. I try install Windows 8.1 64bit and I flash bios to M64.W8ANNA01.ROM from http://www.cnx-software.com/2015/04/...icking-method/ and it was not good... after that the display not show well and when I connect LCD monitor I not see anything (blank screen) and when I connect LCD TV the picture is slightly dilated. Original BIOS version was IZ37.DW8RNNN04. Is there anyone who could give me this bios version? Thank you!
                              It seems to the same Tronsmart IZ37 and CX-W8. Please visit Tronsmart Official Forum and call for 32bit firmware.
                                How about this tool ? Anyone try to dump CX-W8 firmware ? I already update 64bit for OSX86 install.
                                (Intel (R) Flash Programming Tool) aka fptw. Please see attached file.
                                http://forums.mydigitallife.info/thr...l=1#post915084
                                http://donovan6000.blogspot.jp/2013/...-settings.html
