NEW - iMito MX1 - Finless ROM 1.4 - Root, debloat, init.d support
I successfully flashed finless 1.4 today on an MX2 I received 2 days ago. When wifi is enabled, the stick locks up (mouse pointer no longer moves and the stick is unresponsive). Upon reboot, the stick locks up at "loading". Reflashing allows booting but enabling wifi will once again cause it to lock.
HI Guys: After long time communication with the factory, we finally make them to release a new update for the iMito MX1/MX2. The following rom can work both on MX1 and MX2, we have tested. here is the changelog: 1 add the soft power off function, so you can power off the device without unplug […]
Does the MX1/MX2 support HDMI CEC? I couldn't get it recognised under Finless 1.4, but I'm not sure if the hardware even supports CEC. This would make for a much better input mechanism than bluetooth and usb keyboards
I'm on bobs 1.4 rom with my mx1 and absolutely
love it. The only add to make it perfect for my use
is to have the ability to hide the status bar and power
off function. I think with these 2 features added I
would have no real need to switch to another rom.
wifi works perfect for me also on my mx1 with bobs
1.4.
It will be latest ROM with both the 720 and the 1080 kernels so you can choose.
xbox.ko, cifs.ko, md4.ko, tun.ko
It will have all the features of the new ROM of course and be debloated and rooted.
Perfect, just in time for when I get my device on x-mas thanks bob!!
We are not worthy.
Is 720 version based on 11/29 official one, and 1080 on the beta posted by @geekbuying?
Thanks Bob.
OM
BTW, Geekbuying got iMito MX 2 now for $58.99.
We are not worthy.
Thanks Bob.
OM
I believe the one he is currently using is based on 11/20
I will... in fact I will give many options for memory formatting.
Unfortunately I lied... it will not be today! I have a lot more testing to do to bring this to you 100%. So I need a little more time.
I'm sure I can speak for most when I say take your time... the more confident you are that it is working 100%, the less headache you will have from people posting problems. For something this awesome, I can definitely wait
