NEW - iMito MX1 - Finless ROM 1.4 - Root, debloat, init.d support
    I can do a new ROM with the new 1080 kernel from Imito. But as people have said that kernel is a little laggy. There is only so much tuning I can do o help that (not much).
    But if you all want I can whip somehting up for you all to try.
    I did not find it to be buggy however the resolution was awful on my 720p 32 inch. I would use that rom if it could display proper on my screen. How can we add the hide feature to the bottom bar on your 1.4 finless?
    Ben
        I can make the ROM contain both kernels. older 720 and new 1080. You can choose fto flash what you like and in both cases it will have the hjide status bar. I will also ad the xpad.ko, tun.ko, etc modules.
        Anything else needed on it?
          ANyway to make it so you don't have to reconfigure your bluetooth devices after every restart?
          Ben
            Thank you for all your work on this. What a great HTPC packed into such a little mobile stick! Did The creator of TV Launcher Pro indicate that he would let you put his free edition onto your ROM? I seem to remember that?? It is a great choice of Launcher. Problem is it has to give a choice of Launcher each time. Just a thought..no worries.
              I think this is the best!!! Maybe the power off function too, along with your restart option. Thank you for everything!
                There is no power off function in hardware that I am aware of. Only MK808 has a "sort of" power off option. It will power off but you still have to unplug to power it up again.
                  SO you are aware the restart feature does not work on the mx2
                  Ben
                    Ben
                    Are you talking about the reboot APP I put in all my ROMs? Or is this something that is coming with the MX2?
                      I mean the the soft power off function they added on the 29th Nov firmware. It powers off the device but of course you have to unplug in order to power on again.
                        Sorry it does work just needed superuser access
                          hi bob,
                          is it possible to add the driver for the usb2lan (chip: smsc9500) adapter (levelone usb0501) as i mentioned in post 201 (see below)?
                          thx in advance,
                          toby
                          Originally posted by canedha View Post
                          @finless
                          first: thx for this great rom!
                          i was wondering if it would be a lot of work to include more drivers into your rom?
                          in my case it would be the driver for a usb->lan adapter (which i think would like to use many other people as well)
                          a link to the driver is : https://android.googlesource.com/ker...usb/smsc95xx.c
                          another link would be for the smsc chip: http://www.smsc.com/Products/USB/USB...9500A/Download
                          hope these are the files needed...sorry but i'm an absolute noob in this field...
                          if you don't have time for that could you probebely give me a hint or tutorial how to do it? i'm not lazy... just unexperienced...
                          thx for ur help and great work!
                          cheers,
                          toby
                            That is a c code and must be compiled. No sources for the tree to compile it. So unless you can find one pre-compiled as a .KO file, I wont be able to add it. Might be possible to compile it under the open source kernels we have but I am not a kernel guy so maybe you can get someone to compile it for you.
                              oh ok... then i have to find one
                              do u probabely know somebody here who might be able to help?
                              thx,
                              toby
                                @finless
                                hi,
                                found a smsc9500 .ko file:
                                is this something that u can work with?
                                sorry if it's not the right stuff, as i said i'm a linux/android noob...
                                cheers,
                                toby
