NEW - iMito MX1 - Finless ROM 1.4 - Root, debloat, init.d support
    Does Root Explorer work in this rom?
    I haven't had time to flash this rom yet. Just got my iMito yesterday, and I really need the wifi-fix.
    Just wondering if Root Explorer works as it should on this rom? I know a "light" version comes with the original rom, but I didn't successfully manage to remove it to install the original (purchased) version of Root Explorer. It wouldn't install from the market, and when I managed to install it from an .apk, it didn't really work as it should. I just closed on me after displaying the file-tree.
    If it works on this rom, I'll flash it for sure when the new release comes out. Looking forward to it! That, and the increased space for installing apps.
    Thanks for you work, Bob!
      I had to install es file explorer, enable root mode, delete roo texplorer from system/app then install the real market one
        Thanks for replying. It worked for me as well now. Don't know why it didn't work yesterday. Weird! Either way, thanks for making me try one more time!
          How to get an automatic bluetooth connection
          I'm using Rii Mini Bluetooth keyboard and it works fine (http://www.amazon.fr/dp/B008JBTL7A/r...430471_3p_dp_1) but my concern is that to activate it I need to enter in the bluetooth menu to connect to the keyboard... and to do that I need a usb mouse.
          Is there a mean to get an automatic connection once the bluethooth keyboard is activated ?
          connection is lost each time the keyboard enter in standby to save power.
            After flashing 1.4, can I flash the update.zip with the new firmware?
              Thanks for all the time you developers ( I presume mainly Bob) put in to this project!
                I dont think so
                I tried to do so and it replaced the Finless ROM.
                  Will this device get the 1080P update?
                    But everything still works fine? I seem to have wifi issues after Finless rom. Not sure if its the Rom or not... XBMC buffers all the time after the custom rom =(
                      Probably not possible until we get source for wifi drivers!!!!!!
                        Damn I was hoping soon.
                          All works fine!
                          Finless Rom works great. XBMC works great (except known issues with android version), I had to reinstall Finless ROM afterward because firmware update wiped it off. All works good. Thanks Bob.
                            NEWS 1080p ROM
                            I just got my hands on a release from MX1 that says it is 1080P. I will be checking it tonight so stay tuned for a possible ROM.
                              Wow. Exciting. Thank you for all your work.
                                I hope it is true too! I hope also that they don't have "stollen" your work again (as they did with your hide status bar script).
                                Waiting to receive my MX1...
