Any ETA on release? Just curious and looking forward to your release!
NEW - iMito MX1 - Finless ROM 1.4 - Root, debloat, init.d support
Originally posted by hhdroidx View PostHi finless
please could you include spanish keymapping support on your next release ......... spanish.kcm spanish.kl files thank you indeed
Originally posted by Finless View PostGive me a link to download those files and as long as they are not copyrighted in some way, I can include them.
here you have a couple of links.....
as far as i have seen these files does not contain any copyright claim inside.....
thanks again.
hhdx - 2012
tested on ug007!!!
Originally posted by socialexandru View PostDid someone had try it? Mine MX1 will come next week hope so :-D
It's suitable for ug007 too as hardware is the same. Antutu benchmark 6500 points. It's less then original by 1000 points. Used usb port of laptop as charger. Maybe it was not anought current. By the way, my laptop is not booting after reboot with ug007 connected. So i do not recommend to use your PC USB as charger . As for me firmware is very slow! Sometimes letters are printed 200-700ms after you print them. Windows switching takes 1-2 sec, webpage load up to 5 sec.
Big dissapointement is firmware has no more correct support for my external USB touchscreen (VID 04b4, PID c001).
it "operates" only in 1/4 of screen
i understand that i need a configuration file, but i lost stock firmware for ug007.
Bob can you fix this in your firmware? I think if there no config, system must use 1920x1080 surface size.
thank you!
Code:from logs: W/Vold ( 82): subsystem found in netlink event D/Vold ( 82): usb, 1 D/Vold ( 82): == current usb device: 04B4/C001 === W/Vold ( 82): subsystem found in netlink event D/Vold ( 82): usb, 1 D/EventHub( 268): No input device configuration file found for device 'Touch__KiT Touch Computer INC.'. I/EventHub( 268): New device: id=10, fd=112, path='/dev/input/event5', name='Touch__KiT Touch Computer INC.', classes=0x80000014, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, usingSuspendBlockIoctl=false, usingClockIoctl=false I/InputReader( 268): Device reconfigured: id=10, name='Touch__KiT Touch Computer INC.', surface size is now 720x720, mode is 1 I/InputReader( 268): Device added: id=10, name='Touch__KiT Touch Computer INC.', sources=0x00001002 W/Vold ( 82): subsystem found in netlink event D/Vold ( 82): usb, 1 E/NetlinkEvent( 82): NetlinkEvent::FindParam(): Parameter 'DEVTYPE' not found
This is probably going to be now missing in the kernel. I wont be able to help because we do not have all the drivers to compile the MX1 kernel right now.
Hi all, I'm new to the forum and wanted to say hi. I recently picked up a imito mx1 that arrived with old stock firmware on it. I played around with it as is for about an hour and overall was fairly impressed with the performance of this stick. Even wifi was excellent without issues. I then loaded finless 1.4 and what an upgrade over old stock fw. I love this thing even more now and wanted to say thanks to bob for his efforts. Well done!
Cheers and happy holidays from Canada
Jeff
thank you!
Code:W/Vold ( 81): subsystem found in netlink eventD/Vold ( 81): usb, 1 D/Vold ( 81): == current usb device: 04B4/C001 === W/Vold ( 81): subsystem found in netlink event D/Vold ( 81): usb, 1 D/EventHub( 294): No input device configuration file found for device 'Touch__KiT Touch Computer INC.'. I/EventHub( 294): New device: id=8, fd=105, path='/dev/input/event5', name='Touch__KiT Touch Computer INC.', classes=0x80000014, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, usingSuspendBlockIoctl=false, usingClockIoctl=false I/InputReader( 294): Device reconfigured: id=8, name='Touch__KiT Touch Computer INC.', surface size is now 1280x720, mode is 1 I/InputReader( 294): Device added: id=8, name='Touch__KiT Touch Computer INC.', sources=0x00001002 I/ActivityManager( 294): Config changed: {1.0 0mcc0mnc en_US sw720dp w1280dp h672dp lrg long land finger -keyb/v/h dpad/v s.5} D/PhoneApp( 576): updateProximitySensorMode: state = IDLE
Originally posted by Finless View PostThis is probably going to be now missing in the kernel. I wont be able to help because we do not have all the drivers to compile the MX1 kernel right now.
Now it's even faster then stock firmware and touchscreen work great!
I hope final 1080p firmware will be ok too
Thank you from Ukraine!
There are currently 2600 users online. 5 members and 2595 guests.
