I unbrick m8s HOW TO included - now i need firmware ROM M8S model: KCA-003
Originally posted by hipisxbit View Post
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
maybe the zip you mentioned inside the downloaded zip is the actual rom, only this will be flashable with twrp, read the huge post carefully ,i already explained that
i think u-boot.bin and bootloader.img is the same thing but i am not sure ,i believe these are the instructions of what to load during boot
if you want to continue flashing roms until you find one you are happy with, try to establish a sequence of moves that brings your device back to working order in any given situation
the huge post of instructions you read before is mine
this gives you confidence to try roms without fear
After trying every single ROM I found in this forum, that's the only way I revived mine. http://freaktab.com/forum/tv-player-...=1453546137050
With this zip n200C-ota-20151110.zip I made one sd card with amlogic sd bootcardmaker. Put the SD Card, press the AV hole with a toothpick plug it to the power (in this order) and bum, the m8s got a blue light and started flashing the ROM.
After that I flashed the 5.1.1 rom of this forum https://translate.google.es/translat...7576%26st%3D80 look for the firmware 5.1.1 for pufganda (llc) file. I do not tried the network card cos I do not need it, but at least the system detects it. Rom seems stable enough alltroutgh it is made for the m8s+. I have tried several roms of that russian site, and all seem to work.
I repeat, thats the only way, at least for my m8s which seems a pufganda one. I bought it on aliexpress to Vensmile vendor.
Also, I asked my vendor for recovery, and he send me a link https://mega.nz/#!KssyBK5T!fEBUBr9KG...65mbiSZ24eJz9I to a rom to be flashed via Amlogic Bootcardmaker method
This is the new lollipop firmware that seems stable on my m8s http://chinagadgetsreviews.com/downl...8s-tv-box.html . It is the same of the russian site. I have not tried remote (I have a t2 airmoue) nor ethernet, but in the rusian site they talk about a fix for the remote.
Originally posted by hipisxbit View PostHI. ( Sorry for my english )
My device M8S is tottaly bricked. Until the brick this device looged to google store, google loged this device as SkyKirin MS8. ( AMLOGIC S812 2g/8g)
I need firmware for this device ,i dont remember everting , but i looking android settings it seems to me i fund "SkyKirin and "n200".
history :
I flash in sdcard megatron firmware for m8s and ms9 , work fine , but wifi not work, so i download newer fimware form chinagadgetsreviews named cyx_m8s_ap6330_8g2g_150728_SD升级.
When update start for sdcard, i wait very long time...updating...updating...lopping :/ So shutdown device - power adaptor out.
Now device is totally bricked , no recovery , no start form sdcard ( normal update and bootable micro SD not working, different firmwares ) , and my tv display "no signal". Only my router see this device ethernet connected when is power on.
Last chance is USB burnig tool , so i need img file.
I soldering 2 pins , i read this unblock USB-OTG , and he ordered USB cable.
Board :
MODEL KCA-003
VER. V1.0
DATE 150422
I am counting on your help guys.
Originally posted by hipisxbit View PostHere is :
1. Amlogic boot card maker - https://drive.google.com/file/d/0B8u...ew?usp=sharing
2. autoboot.zip - em9 img firmware + burning ini - https://drive.google.com/file/d/0B8u...ew?usp=sharing
3. Stane_20150204-eny_m9.zip - https://drive.google.com/file/d/0B8u...ew?usp=sharing
Download all and unzip.
Create boot sd card :
Find 1-2 gb sc card and put in to card reader , connect to pc usb.
Run Amlogic boot card maker, chose drive letter your sd card , select u-boot.bin from unpacked autoboot.zip - create bootable sd card.
Copy files from autoboot to sd card root directory : aml_upgrade_package.img, u-boot.bin, and aml_sdc_burn.ini - from new_autorom folder
Next :
1. Put hdmi cable
2. put sd card into device
3. holding the av pin
4. power on
You should now upload to the software. The LED should blink. if not , try a few times. If this does not help, you should use the method of short NAND pins . I used play dough and needlesI put the post with play dough to keep the needle
Next :
1. Put hdmi cable
4. power on
Now he must upload software. When finished it will restart and begin to start.
Do not worry if the software itself will load and TV box does not start to an end , it will blink Launcher window - loop .
Then turn off the power.
Take your SD card , delete files on the PC with the exception of u- boot.bin , this file needs to be ,and copy the files of unpacked Stane_20150204-eny_m9.zip
Next :
1. Put hdmi cable
4. power on
You should now upload to the software. If not you are in recovery mode , and flash manual update from sdcard - eny_m9-ota-20150204.zip
This firmware works - but no wifi , and 4gb memory only.
If anyone can improve the translation , please send me a message
Originally posted by sakal View PostHi all, i just unbrick my device, i got email from seller with FW and after copy on SD and than boot with av hidden pin pushed , update process work well. After reboot everything is now working, wifi, bluetooth, 1080p, everything is fine. Name of FW is : m8s_ap6330_8g2g_150728_SD鍗囩骇.rar
link
Thank you
For anyone with the kca-003 board who has no WiFi or Bluetooth, after much searching and experimentation I found a burning tool image that actually works and I couldn't not share it.
For some reason it didn't boot without using a u-boot.bin on the SD card that I know works but I worked out how to just flash the u-boot and all is fine. You may find that yours boots without the extra step. Good luck!
Learned a lot on this page, I was able to recover it using the shorting pin method, thank you OP
However, I haven't been to able to get the right firmware, the lollipop firmware described above from m8s+ does work however every time the box is restarted, it is stuck at m8s+ logo initiallty.
I was so wrong to play with this box. As far as I can remember, every firwmare that I have used has blue initial logo like blue m8s, m8s+, etc.
My last firmware that came with the box had yellow logo but it never said m8s, it always said S812 IN YELLOW, like the picture attached. If anyone got that firmware where your boot up logo is yellow. please upload it. There is a youtube link to a review where guy is doing a review with this box, I have asked that youtuber but no responseYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
hipisxbit
Thank you hipisxbit for this post, using this and other methods I was able to revive my box, rest assured I am not touching it for a long time.
Here is my procedure to unbrick your m8s kca-003 v1.0 20150422 s812 board. It is not s812 btw lol
THIS IS THE FIRMWARE WHICH WORKED FOR MY BOX, https://mega.nz/#!ucg3CZ6K!ponzBEq4N...x_e6F1Atl3cuKA
The issue with this firmware is that when it is restarted it stuck at initial logo, this is issue with the recovery. In order to solve this load up TWRP recovery for M8N on sd card, PRess and hold av port button then plug in with power. keep pressing the av port button until its pass S812 logo. Then install from sd card the recovery then restart the box. It should work. HOWEVER, if you shut down the box by pulling the wire, and put it back, the firmware might be stuck at initial s812 logo, to pass this you need to enter into recovery then go on reboot system and it should work.
I got this from russian forums over at http://4pda.ru/forum/index.php?showtopic=677576
The problem was with other firmware was that although they were meant for ap6330 wifi but it never worked. This firmware works and its stable enough with bluetooth wifi working, remote working, it is not rooted but I rooted using s89 root update zip file. ALSO THE BLUE LIGHT DOES NOT WORK ON MINE ANYMORE, after updating with this firmware.
I learned a lot but chinese boxes never again. THank God
Follow is my procedure to unbrick from dark screen meaning a dead box with blue light on
No.1 : UIsing Usb Tool
Download usb tool here and follow this youtube video made by just me roms https://www.youtube.com/watch?v=1o7K...&nohtml5=False
This is the only amlogic usb tool which worked with my box and it was able to detect, these chinese boxes are are very inconsistent, meaning it works sometimes and sometimes it doesn't, Trick is in order to detect your box with your computer keep pressing the av port button while plugging in and out until it is detected. When you are done with this video, you should have working box atleast a box that can boot and show some screen. Now you can use my firmware above and put it on sd card and install it. Then make sure to install TWRP recovery from m8n variant.
no. 2: SD Card and Pin method ==== just follow great hipisxbit method.
Thank you everyone, if anyone needs help let me know. I hope hipisxbit this firmware works for you and others. Good Luck. I am never buying any chinese boxes againLast edited by asadmari; 07 April 2016, 08:12.
There are currently 1783 users online. 2 members and 1781 guests.
