What should I do now?
I unbrick m8s HOW TO included - now i need firmware ROM M8S model: KCA-003
Hi, the problem was caught and me when updating the firmware. I have the same PCB as Orla. On the unit lights constantly blue LED tv did not see the device.
Due to the lack of options to boot from the SD card (not working), I tried to short-circuit the pins as in your statement - unfortunately also without success.
The device fires up though with USB AA and sees them without a problem usb burning tool. In most img unable to finish the flash.
108k4 img - stops at 2%
M82_110k4_533.img - the same
M8S.STAGE1.NO.WIFI.BT.img - Flash 100% and there is no change.
Someone has any idea what you can even try?
M8S S812 ori default 4.4.2 KK
Originally posted by hieuhienvn View PostHi, so with my mainboard, what are the PINS I need to short? I don't know about "SK Hynix H27UCG8T2ETR BC", what is it? I short PINS 17-18 because I see it same as M8 so I do like this topic: http://freaktab.com/forum/tv-player-...our-m8-m8n-h8m
If you do not know what ... do not short pins . Should be write on it. Name and numbers . Take picture PCBs, and show me. Without information, I do not know how to help you.
Do you remeber Name of the device M8S n200 , or M8S n200c ??
Where you buy this device ?
Which manufacturer ? Is a clone ?
First you have to try to run TWRP from the SD card , if I have more information , I'll try to prepare this for you.
Originally posted by piter_ldz View PostHi, the problem was caught and me when updating the firmware. I have the same PCB as Orla. On the unit lights constantly blue LED tv did not see the device.
I Saw the theme for this forum, the problem uploading of 2% has been resolved, but I do not remember how , search/look it was about a month ago . Do You asked Orli for a copy of the software ?
Envoyé de mon Nexus 5 en utilisant Tapatalk
Hello everyone! Somebody help me ! Recently i bought a TV BOX from aliexpress and now i have a lot of problem with it. This is the link from Aliexpress :
I tried to install root accces but no chance because was impossible to enter in recovery menu. I decided to flash this TVBOX with this firmware :
http://chinagadgetsreviews.com/downl...-tv-box-2.html and now i have a brick. No blue light, not TV signal just ethernet and optical light.
Model M8S
board n200
Model KCA-003
What should i do ? Please Help
Originally posted by electronix001 View PostHello everyone! Somebody help me ! Recently i bought a TV BOX from aliexpress and now i have a lot of problem with it. This is the link from Aliexpress :
Model M8S
board n200
Model KCA-003
[ATTACH=CONFIG]n546975[/ATTACH]
I had the same MODEL , I failed to find any firmware , which would handle the wifi. If you want to work here are the files needed to unbrick , the method described earlier in this topic .
First you try from folder autoflash form sd - auto1.zip
next from folder twrp - recovery.img ( boot from sd card witch u-boot.bin )
next TWRP flash from folder firmwares - FS995676-0924.zip - works fine, but no wifi
Originally posted by hieuhienvn View PostHi, I was try your way but my M8S still can not turn on to install the firmwareIt's no led now, I can connect it with USB Burning Tool but it can not install any ROM. Please let me know what should I do now? I have some boxes M8S have this problem and I want to resolved by myself, if not, I need send back for guarantee.
My steps:
1. Put HDMI cable
2. Put SD card into M8S (SD card have been create "u-boot.bin" from "AUTOROM folder" with SDCard Maker and copy 3 files: aml_upgrade_package.img, u-boot.bin, and aml_sdc_burn.ini - from new_autorom folder in to it)
3. Holding the AV pin and short NAND pins 17-18 (like on the picture)
4. Power on
But nothing on the screen and the LED is still turn off. I was try with more M8S and have same result. What I was failed in my steps?
Try another u-boot.bin, if you have HYNIX NAND H27UCG8T2ETR BC, short pins 29-30, not 17-18
Hi, finally i "unbricked" my M8S KCA-003 with this firmware M8N-M8S_Amlogic_11152015.zip , description we have brand M8S+ not M8S board is n200c not n200 like a previous stock firmware. Without WIFI and problems with ethernet port, after 5 or 10 minutes auto logical disconnect and i must to turn on it again. Somebody can help me to solve this problem definitely ? For the future I'll never buy chinese shit. I opened a dispute on Aliexpress with this seller.
SK Hynix H27UCG8T2ETR BC- is NAND memory.
With this PCBs, where are the position of pins 29-30?
Guys, here's to keep the firmware box M8S AMLogic 812 (processor S812-H, board MODEL: KCA-003 VER: v1.0 DATE: 150 422) with a normally operating modules Wi-Fi, Bluetooth, LAN. The firmware provides several options for drivers Wi-Fi, Bluetooth for compatibility with "exotic" variations M8S.
Having examined the firmware foundthat it laid the driver:
Wi-Fi: AP4335, AP6181, AP6234, AP6330, BCM4335, BCM40181, BCM40183, BCM43341
Bluetooth: BCM4330, BCM43341, BCM4335
LINKS:
KOT49H.20151110 test-keys
1. http://4pda.ru/forum/index.php?showt...#entry45955912
2. https://yadi.sk/d/_r5daYAAmiCG4
3. https://cloud.mail.ru/public/MqKp/63RYkq9bj
4. https://drive.google.com/file/d/0B24...NUb3VtTWc/view
5. http://www.ex.ua/97322250?r=97322212
TWRP 2.8.7.0 M8N.img
TWRP 2.8.7.0 M8N.zip
Originally posted by Morikone View PostGuys, here's to keep the firmware box M8S AMLogic 812 (processor S812-H, board MODEL: KCA-003 VER: v1.0 DATE: 150 422) with a normally operating modules Wi-Fi, Bluetooth, LAN. The firmware provides several options for drivers Wi-Fi, Bluetooth for compatibility with "exotic" variations M8S.
LINKS:
https://yadi.sk/d/9o5GgYHtmjVfx
I just saw and downloaded your ROM, i didn't tryed it yet but it seems to be identical to the one already installed into my device.
Can you tell me if this is the official ROM for my device and if a device with this working ROM can be considered Original? (M8S N200C, the WiFi is a Murata XJ-A KM3201###)
Anyway, the TWRP you just uploaded does work with this M8S?
Unfortunatly i can't connect my device to the PC and i can't find a way to backup my current ROM, so i don't want to screw this up installing other roms or recoveries before i'm sure that i can make mistakes going back to a working state.
Thanks!
Salute fellow m8s troubled owners
i own a mbx m8s n200c 2gb ram 8gb which i bricked (original firmware was KOT49H.20151110)
i followed these instructions apparently with wrong img for my box
the box boots with blue light but freezes at the beginning of mbox logo and i cannot enter recovery at all
i believe i must use USB.Burning.Tool to flash a compatible n200c img file just to recover basic functionality and recovery menu but i cant find such file anywhere
any thoughts?
please help ,i torture my self a week with this damn thing
Apparently you have my same device, use this rom http://4pda.ru/forum/index.php?showt...#entry45955912 provided by Morikone, it should work
yes friend thank you , i found it and downloaded already
the problem is that my box is bricked and i cant enter into recovery mode so that i can flash it
i try to find any compatible rom in imageXXX.img format to flash it via usb.burning.tool so that i can have recoveryLast edited by redshift; 12 January 2016, 12:33.
There are currently 2910 users online. 1 members and 2909 guests.
