LED is red and no remote control. Wifi is working but at once it stopped received data from google play allthough it showed good conenction and 5Mbps and the AP is in the next room. However ethernet is working good. Now I am considering if there is a chance to make it normal booting and remote contro or to send back to the seller. This firmware is good - rooted and google play work. It still strange that the sd card is not mounted for some reason allthough the box loaded from it.
I unbrick m8s HOW TO included - now i need firmware ROM M8S model: KCA-003
So FYI i found a firmware which works perfect, i can flash as often as i want to:
n200-ota-20150307.zip
(uploaded for u: https://www.wetransfer.com/downloads...0130313/2a7dc9 )
(please refer my older posts to check if you have EXACT the same PCB layout! else you maybe will brick your device!!)
Originally posted by Skiller1212 View PostMy problem is the light is blue and any device detect the tv box
Enviado desde mi MI 3W mediante Tapatalk
You can try boot from SD card , with u-boot.bin and TWRP ( u-boot.bin must be for you device )
Download TWRP for m8N , and n200 form here : http://freaktab.com/forum/tv-player-...mlogic-devices
Copy first one to sd card and rename it to recovery.img
Then download my u-bootbins : https://drive.google.com/file/d/0B8u...ew?usp=sharing
and try in sequence each one of them ( copy to sd card and rename u-boot.bin.
Then put sd card, click av pin , power on , and after 5 second unclick av pin.
Try different combination , and tel me if device boot. If not tell me too.
OK People after a weekend of trying different roms ETC I managed to unbrick my MX3 M8s without shorting pins etc. I made a video as there wasn't much around and other post have helped me find my way to t a solution . So I hope this works for some people. Watch the video first then if you think it can work for you give it ago. let me know feedback . Its not very professional as I filmed on an iphone.
https://www.youtube.com/watch?v=t_fMCUXwF4Q
Merry xmas to all . Hope you get your box working again.
Files required, including stock ROM - https://www.adrive.com/public/XxjkFp...ick%20File.zip
Its a large file so watch the video first.
Originally posted by hipisxbit View PostHere is :
1. Amlogic boot card maker - https://drive.google.com/file/d/0B8u...ew?usp=sharing
2. autoboot.zip - em9 img firmware + burning ini - https://drive.google.com/file/d/0B8u...ew?usp=sharing
3. Stane_20150204-eny_m9.zip - https://drive.google.com/file/d/0B8u...ew?usp=sharing
Download all and unzip.
Create boot sd card :
Find 1-2 gb sc card and put in to card reader , connect to pc usb.
Run Amlogic boot card maker, chose drive letter your sd card , select u-boot.bin from unpacked autoboot.zip - create bootable sd card.
Copy files from autoboot to sd card root directory : aml_upgrade_package.img, u-boot.bin, and aml_sdc_burn.ini - from new_autorom folder
Next :
1. Put hdmi cable
2. put sd card into device
3. holding the av pin
4. power on
You should now upload to the software. The LED should blink. if not , try a few times. If this does not help, you should use the method of short NAND pins . I used play dough and needlesI put the post with play dough to keep the needle
Next :
1. Put hdmi cable
4. power on
Now he must upload software. When finished it will restart and begin to start.
Do not worry if the software itself will load and TV box does not start to an end , it will blink Launcher window - loop .
Then turn off the power.
Take your SD card , delete files on the PC with the exception of u- boot.bin , this file needs to be ,and copy the files of unpacked Stane_20150204-eny_m9.zip
Next :
1. Put hdmi cable
4. power on
You should now upload to the software. If not you are in recovery mode , and flash manual update from sdcard - eny_m9-ota-20150204.zip
This firmware works - but no wifi , and 4gb memory only.
If anyone can improve the translation , please send me a messageIt's no led now, I can connect it with USB Burning Tool but it can not install any ROM. Please let me know what should I do now? I have some boxes M8S have this problem and I want to resolved by myself, if not, I need send back for guarantee.
My steps:
1. Put HDMI cable
2. Put SD card into M8S (SD card have been create "u-boot.bin" from "AUTOROM folder" with SDCard Maker and copy 3 files: aml_upgrade_package.img, u-boot.bin, and aml_sdc_burn.ini - from new_autorom folder in to it)
3. Holding the AV pin and short NAND pins 17-18 (like on the picture)
4. Power on
But nothing on the screen and the LED is still turn off. I was try with more M8S and have same result. What I was failed in my steps?
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by hieuhienvn View PostHi, I was try your way but my M8S still can not turn on to install the firmwareIt's no led now, I can connect it with USB Burning Tool but it can not install any ROM. Please let me know what should I do now? I have some boxes M8S have this problem and I want to resolved by myself, if not, I need send back for guarantee.
My steps:
1. Put HDMI cable
4. Power on
WHY YOU SHORT PINS 17-18 ?? DO YOU HAVE NAND (SK Hynix H27UCG8T2ETR BC) ???
Hieuhienvv, short pins NAND works to me in the same position but in the left side of your picture. Sometimes I had to try 3-5 times to works.
Regards.Last edited by CPYM_CL; 24 December 2015, 05:00.
There are currently 4582 users online. 0 members and 4582 guests.
