The point of this test is to see if I can increase SYSTEM to be large enough to accept a EXT3 file system.
So download this ZIP file and please make sure to do things like before.
Use the TEST1 kit that flashed and worked.
Replace from this ZIP file the parameter file into the good flash kit in /image. Parameter file goes in /image. Again PLEASE make sure you replace the exiting file!!! A mistake here and it will not work!
Then at the root of the folder for the good flash kit, replace the settings.ini file with the one from this ZIP file.
This really should work this time.
To make sure you have in fact replaced the files, the parameter file used by the flash tool should say this:
Note the change in size for system and offsets from that point on!
You can open either of these files in Windows Notepad BUT DO NOT save them! Notepad will hose them as they use linux line endings!!!!
FW_VERSION: 1.0.0
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 1616
CHECK_MASK: 0x80
KERNEL_IMG: 0x60008000
COMBINATION_KEY: F,0,1
CMDLINE: noinitrd console=ttyS1,115200n8n fbcon=rotate:3 init=/init root=/dev/mtdblock2 mem=208M@0x60000000 mtdparts=rk28xxnand:0x00002000@0x00002000(misc),0x 00004000@0x00004000(kernel),0x00002000@0x00008000( boot),0x00004000@0x0000A000(recovery),0x00080000@0x0000E000(system),0x0004A000@0x0008E000(backup),0x0003A000@0x000D8000(cache),0x00080000@0x00112000(userdata),-@0x00192000(user)
The new settings.ini should say this:
The offsets should match the parameter file!
Parameter_Offset=0x00000000
Misc_Offset=0x00002000
Kernel_Offset=0x00004000
Boot_Offset=0x00008000
Recovery_Offset=0x0000A000
System_Offset=0x0000E000
Backup_Offset=0x0008E000
Flash the entire ROM erasing IDB and clicking the loader.
Here is the new file download link:
http://video.freaktab.com/?subpath=f...filestest3.zip
Let me know! I hope this works
