overclocked kernel is here
Originally posted by Gasp View PostVideo playback is smooth only when there is some overlay activity - such as mouse movement / fading, sliding UI.
When everything is still and only video is playing - it skips frames again.
(isn't there any kind of overlay app that would keep moving some transparent image?)
Originally posted by sam321 View PostThe video frame skipping as been fixed. Please update the kernel you are running by going here http://www.freaktab.com/showthread.p...h-RTL8188-WiFi
Re: overclocked kernel is here
Originally posted by Gasp View PostMy bad, i didn't realize i can't just flash a kernel. Whole reflash was required.
Cheers
Sent from my GT-S7562 using Tapatalk 4FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
My Plexi MK802IV mod
http://www.freaktab.com/showthread.p...xi-MK802IV-mod
Originally posted by sam321 View Postfor only the old MK802-IV or UG007B or QC802
before I start just let me tell you that you are doing this at your own risk
I have been working on something this last day or so and now it is time to share it with everyone. This android stick suffers from a lack of good roms, there is only really neomode working on it. So I present to you a ported rom,all thanks go to the original author of this rom, I have just made it work on our sticks. This is the fastest android 4.2.2 rom that I have known, but the neomode rom is Very Good to.
the android version is android 4.2.2
original author of this rom is Finless
name of original rom " CX-919 4.2.2 - Finless ROM 1.4"
no known issues
what works
everything including bt and wifi
on first boot the screen may stay blank, do not unplug the stick, the recovery is working at this time setting up the system. Wait at least five minutes before unplugging the stick, but you should not have to do this
Replace The recovery with this one if it does not boot http://www.cloudstor.es/file/m1_NDg0Mw/
link to ported rom download here http://www.cloudstor.es/file/m1_NDgwOA/
So you are probably asking yourself how fast is it, well if you are lucky enough to use the overclocked gpu kernel this is what you will get
i couldnt use sixaxis controller with bluetooth ps3 controller
any ideas to how to get it working?
and heroes of order and chaos, i cant play...
and 4.1 rom i have troubles with xbmc
Originally posted by Leandro View Posti couldnt use sixaxis controller with bluetooth ps3 controller
Hello there!
Thanks for your awesome work, Sam!
I have the mk802IV with the new wi-fi chip.
I flashed OC Kernel (1080p 1.7ghz ram 1400mhz kernel). Went with a slightly overclocked kernel because atm I can`t provide a better power suply than 2.1amps nor can I cool the little thing. I ordered the stuff from aliexpress and I`m eagger here to try it out (3a power supply and 2x 2,5cm coolers 5V 0,12 amps)
Following the experience from opengl1971 (http://www.freaktab.com/showthread.p...5087#post95087)
I flashed the kernel after flashing Tuen`s rom.
Everything works like a charm, scored 18500 with antutu.
Wi-Fi is ok, it is still weak, but a little better and stabler. BT is working. Video is great.
And the device isn't getting too hot, just a little warm so far. Ran consecutives antutu tests to watch out for heat and so far I`m ok.
Thanks a lot Sam =)
Underclocked kernels
Can anybody give me link to framefixed underclocked kernels for old chip wifi. I need newer than 03 august 2013, because undervolted 03 august not turn off device, but reboot while pressing turn off.
Are any such kernels exist?
Like 1080p 1200 mHz, 1080p 1400 mHz with 1200 mhz memory.
Latest 3 september works fine, but they all overclocked.
Thanks for any help!
Cozyswan S400 with the red dot(near hdmi)
Hi there people,
I'm new to this forum and I've got an issue with my cozyswan s400. I can't play smoothly any 1080p video(or 720p for what is worth).
I tried Moboplayer, MX Player(with/without v7 codec NEO) and I experience small shutters every few seconds
I failed to find a way and I talk to the Chinese woman who sold me this, she's useless(doesn't have a clue and from what I understand she just sells the item and nothing more).
I have an HTC Desire HD and I've played a lot with roms, recoveries etc but with S400 it's a bit different. I want to test a few roms but also to backup the original with nandroid or something. Does anyone know if the S400 is rooted? if not how can that be done.
P.S. All these kernels need a heatsink, even the ones without O/C? (I'm willing to put just a heatsink over the top without cutting any plastic or drill a hole(I can do this but I prefer not to do it), of course placing a heatsink just on top of the plastic won't dispatch much of a heat but it will be something rather than nothing. Any help would be appreciated
works for me
I have a Cozyswan S400 (old wifi chip) and have successfully installed the NEO ROM and OC kernels.
I have perfect playback through MX Player, no stutter at all
This link address for the ROM
There are currently 3475 users online. 0 members and 3475 guests.
