overclocked kernel is here
Re: overclocked kernel is here
Originally posted by sam321 View Postafter some help from phjanderson I can now confirm that it is possible to overclock the gpu, I have been running my stick with the gpu oc to 800Mhz for most of the day, I can finally say that I am happy with my stick now
Sent from my UMI X2 using Tapatalk 4 Beta
Nice
Sam that is great, what is the standard speed (500?) isnt 800 a bit much ?
Could you make a ocerclocked kernel for the J22 ?
(https://skydrive.live.com/redir?resi...HjJ1zmuhpcH5cA)
720p-1.7Ghz-1200 Ram-600 gpu with frameskip fix ?
that would be the best one ever
Originally posted by BaDTaG View Postwaw is this in all of your kernals now? or is it somthing that has to be done by you before making the kernal?
standard speed is 600Mhz. and as for 800Mhz being too much it works fine on my stick, and there are no other options it is either 600Mhz or 800Mhz it cannot be set any different
Is the clock speed of GPU fixed or dynamic like the CPU?
Can the CPU run up to overclocked rates and voltages with an interactive governor?
Great news!!! Thanks for your work!! You are doing our sticks great!!
Originally posted by sam321 View PostRam is 720Mhz stock
I had been dealing with custom kernel issues where they were init'ing at 300MHz (and consequently were resulting
in awful benchmarks) Or were you referring to what it SHOULD be running at stock. lol
I found in the config where to change the init to match the 720 and things run nicely now. I hadn't bothered to
O/C the DDR any further since after setting the DDR to 720 and my CPU to 1.7GHz I've been hitting Antutu benchmarks
of 18,500 and linpacks of 64 (single) and 176 (multi). I'll have to play with some higher freq's if 720 is actually meant to
be stock freq.Question Reality: Find Your Own Truth!
My MK908 Cooling Mod and Breakdown : HERE
My RK3188 Github Repos (NOTE: Works-in-Progress!) : HERE
Sent my Epic4G AND Backflip into nearspace... what have YOU done with your phone?
Want to say thanks for something I did/said or DONATE to my drink fund?
Originally posted by thesawolf View PostThat's odd.. according to dmesg, stock inits at 396MHz, 300 during video, 0 idle/suspend (at least on mk908).
be stock freq.
He has his github on the source list.
be stock freq.
There are currently 3494 users online. 3 members and 3491 guests.
