overclocked kernel is here
    for only the old MK802-IV or UG007B or QC802
    I cannot be held responsible for you overclocking your device and damaging it, remember keep your device cool
    all these kernels have the Frame skipping fix included
    available kernels here are
    720p 1.8Ghz Ram 1400Mhz Gpu 800Mhz kernel
    720p 1.8Ghz Ram 1500Mhz Gpu 800Mhz kernel
    720p 1.9Ghz Ram 1500Mhz Gpu 800Mhz kernel
    720p 1.9Ghz Ram 1600Mhz Gpu 800Mhz kernel Antutu scores 19526
    1080p 1.8Ghz Ram 1400Mhz Gpu 800Mhz kernel
    1080p 1.8Ghz Ram 1500Mhz Gpu 800Mhz kernel
    1080p 1.9Ghz Ram 1500Mhz Gpu 800Mhz kernel
    1080p 1.9Ghz Ram 1600Mhz Gpu 800Mhz kernel Antutu scores 17937
    all kernels in one RAR download here http://www.cloudstor.es/file/m1_NDcyOQ/
    my kernel source already has the video fix applied and includes all of the overclocking code including the gpu. the source http://www.cloudstor.es/file/m1_NDcxNQ/
      Wait for Ap6210
        Originally posted by Howard View Post
        Wait for Ap6210
        i think it is already in the kernel for ap6210... or is this a different fix?
        EDIT:
        doooo
        just realized it is the gpu oc that is included :-P
        so i am with you Howard waiting for ap6210 )
          Big thanks man!!!
          Unfortunately even on this kernel I have this same result in antutu (4000 GPU, 18000 overall). I tested this kernel:
          Probalby I will try build my own kernel or I RMA it. Probably I have damaged gpu because on every kernel and even on 1400MHz CPU max my mxplayer crash (momentairly exit from app or video freeze) and this same is on flash video... even bsplayer has problems with video
            PSU is very important in those sticks.
            leolas
            My devices:
            Gearbest.com)
              leolas
              Yes I know and I have 4A Good PSU.
                Then seems that your cpu or gpu is a bad overclocked
                leolas
                My devices:
                Gearbest.com)
                  leolas
                  What do You mean bad oc? In all parts in antutu I have good results only GPU stuck on 4000 (should be 5500) and this is my problem and I think this is a reason that mxplayer suddenly quit or video freeze or maybe this is mxplayer guilt? Have You any problem with mxplayer (or other player, - which?)? When I watch a movie for example 720p mkv 1:30h every ~10min mxplayer exits or freeze (I set CPU to 300-1400 and interactive mode). I tried everything (or almost everything - looking for solution) many kernels, reflash etc. please any help?
                    Sorry, a typo, I want to say overclocker.
                    I dont have any issue with mplayer. I can't test gpu oc yet.
                    Have you try to change your base rom? Maybe the problem is that. What one are you using?
                    leolas
                    My devices:
                    Gearbest.com)
                      leolas
                      Maybe I should to stream video f.e via minidlna (I tried but subtitles don't shows... txt or srt without difference)? Now I'm playback via samba because my wifi connection is very good 5-6MBps download from my NAS (Zyxel NSA310 1Gbps connected with TP-LINK WDR3600 router).
                      I'm using NEO TV ROM and test with all Sam's kernels... I think I have bad GPU - the main reason is that players exits suddenly and antutu only confirms that it is something with GPU (only GPU result is bad, everyting CPU,RAM,SD R/W etc. is ok!)... but this is only my opinion, maybe I do something wrong?
                        Sorry. I don't know more reasons maybe Sam can give a little more voltage to your gpu. Don't know if it is possible.
                        leolas
                        My devices:
                        Gearbest.com)
                          Same problem here, antutu won't even complete the test and some streaming apps don't run properly (sound and image jumps/skips), this only happens when using the highest 720p extreme overclocked kernel with the GPU over clock (frameskipping fix), using the "normal" highest 720p extreme overclocked without the GPU fix it works fine.
                            leolas
                            Ok, thanks for Your replies
                            Sam, can You write me some about gpu vcc control? Is it possible to change it?
                              I have this problem from stock kernel and any other with or without OC, gpu fix, frame skipping fix - without changes
                                +1 for antutu
                                and for video : any kernel don't work .
                                I try to read record on my Vu+ ; it's ts file: H264 (mAIN PROFILE 4.0)1440×1080 25fps audio AC3 384kb/s 48000Hz 5.1 .
                                Don't work whith archos , mx et vp player .
                                And whith the rmkplayer no sound.
                                Work well whith RK3066 ( MK808B).
