overclocked kernel is here
REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostHeat problem maybe?
leolas... when I play a movie I set 300-1920Mhz ondemandx and mxp quits like I sad in previous post.
Edit:
A moment ago I tested my mk802iv with a air turbine from radeon hd4780 12V... mk almost frozebut nothing changed (17k in antutu).
Maybe tomorrow I will recieve wattmeter and I check power comsumption.Last edited by yerzu; 09 July 2013, 16:30.
watmeter
after wat comsumpton tests I have bad results:
on cpu&mem test : max 15,8W
on 2d test: max 10W
on 3d test: max 10,8W
now we have enough data to say: power adapter is ok, probably something with device... anyone can confirm my wat tests? Now with 20W PS in antutu I have: CPU 9290 (very good), GPU 3935 (very very bad), RAM 3138 (bad), I/O 892 (good) tested on 1920MHz (performence) 1280x672. Is some posibility that I have other revision of main unit (CPU with GPU)? How we can see that CPU is OK but GPU is not good (1500 points less). Please answer, regards!
on 2d test: max 10W
Remember that not all chips can overclock the same. All must get 1,8GHz more than this is a question of luck.
Originally posted by yerzu View PostThis config is not good, try with 1800min and 1920max.
When I set 800-1600Mhz interactive then MX Player run stable even 2h 1080 mkv movie!
Originally posted by sam321 View PostHi BrunoNRG do you want to try using the kernel that I use. The clocks are slightly lower but it is still faster than the 1.8ghz ram 1400mhz and it as proved itsself to be very stable
sorry it as took me a while but I had to wait for my computer to finish something before I could boot it to linux
My kernel http://www.cloudstor.es/file/m1_NDEzMQ/
Originally posted by sam321 View Postsorry it as took me a while but I had to wait for my computer to finish something before I could boot it to linux
Unfortunately, after uninstalling SetCPU to prevent any conflict between the app an the new kernel, flashing your kernel and trying antutu, the device just reboots itself as soon as the benchmark reaches 1%... I find it a bit hard but, is there any possibility that I somehow fried the cpu and now it only supports 1416MHz has it's highest frequency?
well it is possible. Have a look at this http://www.anandtech.com/show/2468/6 but I have been running mine for 24 hours seven days a week and I have not got any problems, maybe I should remove the extreme overclocking kernels just to be safe
Originally posted by sam321 View Postwell it is possible. Have a look at this http://www.anandtech.com/show/2468/6 but I have been running mine for 24 hours seven days a week and I have not got any problems, maybe I should remove the extreme overclocking kernels just to be safe
I cannot edit the first post so I will delete them from the file hosting. What I do not understand is the extreme overclock has had nearly 800 downloads, I would have thought out of all of those there would have been some people that would have posted with the same problem, or maybe the odds are just 800/1 of encountering this problem
Edit: BrunoNRG have you tried plugging a power supply directly into the stick without any fans and with just a mouse, and then running a test, or if you go back to the stock rom is everything okLast edited by sam321; 14 July 2013, 17:22.
There are currently 3949 users online. 0 members and 3949 guests.
