overclocked kernel is here
well I must be lucky with my processer and gpu because I am running this kernel "720p 1.8Ghz Ram 1500Mhz Gpu 800Mhz kernel" and everything works fine. I did hesitate whether to release the gpu overclock, but I thought everyone deserved the chance to try. I can up the voltage but I do not recommend it. Sorry guys, I did try. But if you are looking for a overclocked kernel or one running at stock speed with the video fix go here http://www.freaktab.com/showthread.p...h-RTL8188-WiFi
Originally posted by yerzu View PostBig thanks man!!!
Unfortunately even on this kernel I have this same result in antutu (4000 GPU, 18000 overall). I tested this kernel:
Probalby I will try build my own kernel or I RMA it. Probably I have damaged gpu because on every kernel and even on 1400MHz CPU max my mxplayer crash (momentairly exit from app or video freeze) and this same is on flash video... even bsplayer has problems with video
try a stock rom, then you can know if something wrong with custom kernel or firmware.
I always have some video play problem on NEOMode ROM(screen blurred),after flash back to stock rom,problem is gone.
Originally posted by sam321 View Postso now I am happy with my stick, I thought I would do some optimization and proove that the gpu oc works for me. Pictures speak a thousand words
Antutu scores
What clock speeds did you use to achieve these scores?
Sent from my M6 using Tapatalk 4
WOW, thanks
i've tested this oneOriginally posted by sam321 View Post...1080p 1.9Ghz Ram 1600Mhz Gpu 800Mhz kernel Antutu scores 17937...
About playing video, i'm getting the strange "mouse effect"
when the mouse curser is on screen : smooth , when it's off : choppy ( very choppy on a 720p MKV )
can you tell me wich video player you use ( if it's Mx player, what are the best settings on it ) ?
Hi what is the correct link the firmware that you used on this test? Is it 720p or 1080p? Sorry, but I saw your last links but today you posted this test, I wonder if you are going to upload other files or can I use the last ones?
Antutu scores
Great score, my better one was 18352 in qx1 but in 1080p with 1898cpu 1500ram 798gpu.
Great work sam!!, thanks for your work.
I noticed that gpu overclock put the stick much hotter, so like sam advice take care about temperature and add extra cooling.
Originally posted by BaDTaG View PostJust tryd the 1080p 1.8Ghz Ram 1400Mhz Gpu 800Mhz kernel on my MK802IV (AP6210)
it seams to work well exept offcurs that there is no wifi.
i get about 16500 in antutu
BaDTaG
There are currently 2661 users online. 0 members and 2661 guests.
