Sent from my XT925 using Tapatalk 2
overclocked kernel is here
Re: overclocked kernel is here
Originally posted by CrAcKeZ View Post
Sent from my XT925 using Tapatalk 2Please post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Originally posted by l33boy View PostI have a Cozyswan S400 (old wifi chip) and have successfully installed the NEO ROM and OC kernels.
I have perfect playback through MX Player, no stutter at all
This link address for the ROM
So do you have the S400 without the dot, green dot or red one? Did you have small shutter before?
(The seller send me my S400 on 16 of July I receive it about one month later)
Originally posted by mechaone View PostRunning a solid stream of cool air past the device will provide more effective heat dissipation than a heatsink linked to the exterior of the device. Any heatsink is only as effective as the surface area it is adhered to, and plastic is a terrible heat conductor. Attempting to wick heat from inside the device through a plastic shell will prove futile when the chips become hot enough to heat the air around them within the shell. Use a fan if you are hesitant to pop the shell and directly adhere chip sinks.
It happens to work as a computer repair technician, the fact that I don't want to open the casing has nothing to do with hesitation or anything. I can put some push-pull fans and make it work even from it's power source itself ..just put a microusb adapter male-female and get the power to two small 30-60mm fans or smaller and stick them on top rear of the stick. If you want to get crazy take an old cpu fan(we've got a bunch of these) ..the ones with the old SLOT1 cpus, huge copper heatsink with double fans and it would be cold as ice.
I won't go further putting water on it as it would be lame :P, I'll keep my water for just my cpu.
P.S. I don't mind having tubes outside my computer with my one dual radiator and one single but I do mind having a compact usb stick look like hell (my hdmi connection to the tv is on the left side, it has another in the back but I already use that for another purpose).
Originally posted by CrAcKeZ View PostI have no idea if I have old version or not, I just know that next to the hdmi plug there is a red dot and from a little search I've seen that there is a version with no sticker, with green dot sticker and red dot sticker making the red one the newest of all - That's as far as I've found
I got mine in May this year and I 'think' it had a green dot on it, can't be sure, maybe none at all.
Opening these things up is very easy so have a butchers at which wifi chip it has, then you will know for sure.
YES... That's why I ended up on these forums, the stutter was driving me mad
But now it runs very fast and smooth... thanks to the Freaktab guru's
Originally posted by l33boy View PostGood question... unfortunately I have re-cased mine with RAMsinks and 5V fans LOL.
But now it runs very fast and smooth... thanks to the Freaktab guru's(except if you remove it and you don't remember if you had any and if you had, what colour was it)
I'll remove it today if I find some time, I don't believe it will take me more than a couple of minutes(this small shutters make me feel the video has 18fps or something and yes of course I check it out, the tv can accept usb stick so I tried it there and was smooth as butter). I'll take pictures and post them, then maybe someone would know what to do :P (hopefully it won't end up like my first ever android device, an MID 7" Chinese android 2.2 device - screen stopped working(touch) and I just use it 2-3 times for less than 10 minutes each(unfortunately not a hardware issue as it would be easy to me to fix it) many rom tests but nothing helped. Oh well since then roms have been evolve and nowdays regular people release custom roms)
Anyway about the dots I'm saying again I've hear that it goes:
No sticker < Green dot sticker < Red dot sticker
(Older < Newer < Latest)
Originally posted by CrAcKeZ View PostThe red dot sticker is outside the casing(except if you remove it and you don't remember if you had any and if you had, what colour was it)
I can't remember if it had a green one or none at all.....
Originally posted by l33boy View PostLike I said buddy... I RE-CASED it so I threw the old case away
P.S. I even have the film which was on top of my stick to avoid scratches inside the box (yes I know, I'm a weird guy hahahahaha)
Originally posted by CrAcKeZ View PostI don't throw nothing, I have the original box(it comes handy and helps if warranty needs to take place). So in your case I would have the casing inside the original box
Originally posted by CrAcKeZ View PostSo did you have any shutter with original rom?Originally posted by l33boyYES... That's why I ended up on these forums, the stutter was driving me madOriginally posted by CrAcKeZ View PostOh and something else, how much did you paid for it?
Originally posted by l33boy View PostAbout £60 mate, including a 3 amp PSU... why?
You have stock clocks mate? I'm hoping it won't have any shutter even if clocks are stock, O/C'ing it without cooling it seems stupid and as an overclocker(pc world) I'll avoid it, although after having custom rom I can try to see if two fans(push/pull) can do the trick.
Originally posted by CrAcKeZ View PostTo check if I got it cheap and I did, mine costed 56.2$ + 6$ shipping + 2.48$ charges for a total of 64.68USD that's about 47.75EUR or 40.35 pounds. My power supply is 5v 2A not 3A..but never have an issue with it.
Still, the way these things are advancing, ours will be obsolete by next year!
I've tried both stock and extreme overclock (which is my current kernel) and it is smooth as silk with both.
I have put it in a small metal box with two 5V fans linked to the internal supply and vented at the opposite side through aluminium mesh. You can feel the warm air after it's been running for an hour or so.
Two aerials on the case (BT & WiFi) although I don't use BT at the moment.
I also use a 1TB external mini drive which draws it's power from the box as well.
I open the stick and I took a picture.
Sorry for the image blur but I've got a telezoom lenses so it's a bit difficult to capture at close range(you can see most of the chips quite clearly, auto focus failed me so I had to manual focus to get results)
Just to help you out as I see that the uploaded image is not in it's original size, I'll read you what I see.
Ram chip, 2x GEIL 1318 512X8DDR4 HL 1316(and another two on the other side burried under that flat big heatsink which covers almost all the surface), the flash chip is a SKhynix H27UCG8T2BTR BC , 315AA M22K0158OH, the chip on the left AP6210 T0D4005 1318, the chip on he button ITE IT66121FN 1316-BXG AG0X8A
The board has a date: 2013-05-23 and a code: HTC-T010-V2
In the front(where cpu is located there is another chip which has written ACTIVE 8846QM CD173
---Anyone who can help a bro?---
Originally posted by bigiuly View PostI have a question: if I use 720 kernel and on settings/display/screen size is 1920x1080 this mean the image is upscaled? so is better to use 1080 kernel on FullHD display?
THX
Originally posted by CrAcKeZ View PostNo, when we say it's 720p it means that works smooth at 720p ..it will work on fullhd a video playback for example but not as smooth as on 720p
Sent from my GT-S7562 using TapatalkFIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
My Plexi MK802IV mod
http://www.freaktab.com/showthread.p...xi-MK802IV-mod
There are currently 3031 users online. 0 members and 3031 guests.
